Old 12-16-2008, 12:19 AM
zenkaizen zenkaizen is offline
Problem with HDMI - HD200
For some reason, when I hookup the HD200 to my LCD TV through HDMI everything has a purple hue to it, including the SageTV menu. Hooking up through Component, everything is fine.
I've used the same HDMI cable and hooked the HD200 up to my LCD Computer monitor and everything is fine.
Does anyone have any ideas?
Old 12-17-2008, 02:58 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Did you update the firmware on your HD200? That sounds like an old problem (I used to have it as well a few months back)
Jeffrey Kardatzke
Google
Founder of SageTV
Old 12-18-2008, 12:18 AM
I did and it didn't fix the problem. I do see a new beta firmware is out that is supposed to increase HDMI compatibility so i'll give that a try tomorrow and report back.
Old 12-18-2008, 02:19 AM
Lucas Lucas is offline
It's very intermittent now. I got it a couple of days ago after power cycling the HD200. It only went away after 3 power cycles.
3 x HD300s
Old 12-19-2008, 07:19 PM
Narflex's Avatar
Sage
We've got another beta firmware out now (20081219 0) which has an option in it to force the HDMI mode regardless of what the display says. If the beta firmware itself doesn't fix it; give that option a try and see if it helps. It's in Advanced Setup->Multimedia.
Jeffrey Kardatzke
Google
Founder of SageTV
Strange Music Library Problem (may be DVDPro2Sage problem) Taddeusz SageMC Custom Interface 7 12-27-2008 06:16 AM
Problems with HD100 and HDMI switch scm SageTV Media Extender 4 11-12-2008 01:31 PM
Intermittent Problem - Poor Playback Quality - Vista SP1 martini SageTV Placeshifter 0 10-28-2008 08:31 AM
Program Time Line Problem Steve52 SageTV Software 22 09-10-2008 01:50 PM
Problem going from cable to antenna (NTSC) davi323 SageTV Software 1 08-31-2008 05:50 PM
