Old 01-02-2009, 12:40 PM
len12121 len12121 is offline
Deleted DVD file still on Menu
I am using the HD200 in standalone mode. I have loaded DVD's onto a 1TB drive. I then decided to delete a couple of them. When I select DVD's there appears strange named DVD's that when I choose play are one of the ones I deleted. The original folder is gone but a new folder appears with a strange name ( e.q. $RDF$wd). Any help is appreciated.
Old 01-02-2009, 01:15 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
That's a new one...can you submit a bug report on that so we can get more information from you? http://sagetv.com/bugs.html
Jeffrey Kardatzke
Google
Founder of SageTV
Old 01-02-2009, 03:51 PM
As a followup I could not see any other folders when the Hard Drive was connected directly to the computer. When connected to HD200 I found a $Recycle.bin folder that I could not delete any files in it even though the HD200 was letting me delete them from a menu. Push ok but file was still there.
I then googled $recycle.bin and found on the Microsoft site a way through CMD to delete this foldere. It worked. Now when the Hard Drive is connected to HD200 and I look at DVD's this funky DVD folders are gone and everything looks ok. Maybe someone more knowledgeable in Computers and Hard Drives can tell me if what I am doing should need to be done or should the HD200 not be looking into the $Recycle.bin on the Hard Drive. It seems from the Microsoft article that Hard drives keep their own $Recycle.bin, if so how does it ever get deleted?
STV Import: Read & Write Metadata files for Default STV 5/6 (v2.2.9 18/Feb./2010) JREkiwi SageTV Customizations 251 10-09-2019 11:11 AM
SageTV V6.5.5 Release Candidate is Here! Narflex SageTV Beta Test Software 0 12-23-2008 12:01 PM
Watch a DVD with subtitle from srt file alon24 SageTV Customizations 6 06-05-2007 04:47 PM
Black screen and no audio on Client shatter SageTV Software 7 02-21-2007 08:41 PM
