Old 02-22-2009, 03:15 PM
TheNakedMan TheNakedMan is offline
Netflix
Can netflix Instant Movies be watched on the HD 200?
Old 02-22-2009, 03:22 PM
evilpenguin's Avatar
There are two ways...
1) Play-On - I've heard that this works... sometimes.
2) SageMC Netflix Plug-in + Capture Card Loopback - A very hackish solution, but it due to some quality work by the plug-in dev it actually works amazingly well once you've got it set up.
But neither of them are anywhere close to being as easy or clean as the official support in other boxes like Roku or Xbox.
(You should be able to forum search for details on either solution)
Old 02-25-2009, 05:55 PM
otaku otaku is offline
In my experience, most Netflix movies cannot be watched with PlayOn. Only those that are downloaded as .mpg files and not .m3u files, since the SageTV either ignores these .m3u files or just can't access them.
Most TV shows and other episodic content in Netflix appears to be available on .mpg files. Most movies are .m3u though.
The same holds true for Hulu on PlayOn. TV shows and clips work fine, no movies yet that I've been able to get to work. (Again, .mpg vs. .m3u)
Updating to latest PlayOn and SageTV beta (2/25!), doubt if it will change anything, but keeping my fingers crossed.
Netflix Control: A Netflix Silverlight Remote Control Script brainbone SageMC Custom Interface 59 04-22-2013 01:44 PM
Netflix for Standard UI MrTea SageTV Customizations 12 06-27-2009 01:59 PM
Help with SageTV and netflix please! Tzerial SageTV Customizations 5 02-01-2009 11:25 AM
Netflix API! jrog General Discussion 20 10-30-2008 08:04 AM
Netflix Plugin DwarF SageTV Customizations 8 01-23-2006 08:40 PM
