Old 06-30-2010, 10:47 AM
Qusix Qusix is offline
Question about the User Rating..
When retrieving the User Rating for a movie that has a rating higher than 8.0 from IMDB the User Rating value gets assigned a value of 250 using BMT. Some examples are Dark Knight, Shawshank Redemption, and the Wrestler. All of those movies get a value of 250 for the user rating. Is anyone else experiencing that?
Also what is the formart of the UserRating field? I noticed that if imdb has 5.7/10 the User Rating will have a value of 57. However I have some older properties files that have 5 instead of 57.
Linux Headless Server
Tuners: HD Homerun, 2 HD-PVR, PVR-150
Clients:
2 HD100 Extenders
1 HD200 Extender
SageTV Client
Old 06-30-2010, 11:25 AM
The UserRating is a field that holds a value between 0 and 100. It would appear that there is a bug in the scraper (which is why I loathe scrapers) in that it is pulling another numeric value that must be adjacent to the actual user rating for the imdb provider. I'll add a bug for this an take a look at the scraping code.
In pre 4.1 releases of bmt, it would simply dump text into the UserRating field, which would be inconsistent between tvdb, tmdb, and imdb. In 4.1 the bmt code will always try to put an integer into that field, but it would appear that I still need to do some range checks
Old 12-01-2014, 12:52 PM
kolakowj kolakowj is offline
user rating
Its been a while and I'm still seeing this issue. Are there any plans to address?
Password protect folders, or MPAA rating? CANightHawk SageTV v7 Customizations 8 06-09-2010 12:27 PM
Videos Organized by MPAA Rating, Then Genre osburnfamily SageMC Custom Interface 0 08-31-2008 01:26 PM
Feature request: movie rating joeh26 SageTV EPG Service 5 09-08-2006 01:52 PM
New user with a question. cyberr8der SageTV Software 2 09-10-2005 02:20 PM
Power supply wattage rating 'aint everything mdmint Hardware Support 5 01-15-2005 07:07 PM
