Old 03-01-2011, 07:22 PM
baradanikto baradanikto is offline
HD300 Usb Wireless access
Just got my HD300 and I'm having problems getting the wireless access to work. The 'Wireless' option does not appear on the Network page. The unit came with firmware version 20101008-8. I am using a Linksys usb wireless G adapter. I've done all the preliminary setup on the server (Win7 x64) and have forwarded ports thru my cable gateway.
Please do not tell me that I need a SageTV approved adapter...
Any help would be greatly appreciated.
Old 03-01-2011, 08:58 PM
SimeonPilgrim SimeonPilgrim is offline
Ok I wont tell you that (manly because I don't know the authoritative answer), but where did you get the idea, just any wifi card would work?
Myself I saw that SageTV sold a single wifi card for an ok price $30 (compared to the Tivo wifi adapter ~$70) and thought lets be safe.
Old 03-02-2011, 12:16 PM
rtrski rtrski is offline
Well, I won't tell you that, then....but Sage does provide info on the one approved adaptor for working with the USB port. Don't have to buy from them but it does have to be based on a very specific chipset to be promised to work.
I use a wireless-to-wired adaptor plugged into the network interface port (essentially one half of a bridge, intended for use with things like TVs that only have wired network ports). Won't claim I've been problem free though. I think my network is fine (every test I've done with anything else plugged into that adaptor like a laptop gets great bandwidth) but I do suffer from weird random HD300 slideshow mode sometimes. Still haven't figured out the cause but tend to get it fixed eventually (sometimes by rebooting server and power cycling HD300, sometimes by giving up until the next day when it suddenly 'works'. )
Old 03-02-2011, 12:39 PM
drewg drewg is offline
From the firmware on my HD300, it appears that the only wireless adapter that is going to work is something based on the Ralink RT2870 chipset. I've appended modinfo output which shows what devices the driver supports. You can use something like http://www.linux-usb.org/usb.ids to map the vendor/device to a product you can buy. However, beware that vendors often keep the same product name, and swap out the wireless chipset with a different, incompatible one. That's what makes buying wireless cards for linux a nightmare. If I were you, I'd just get the official adapter from SageTV. For the money you might save, it is not worth the potential hassle.
Drew
tango3[~]# /rw/mipsel/modinfo /lib/modules/rt2870sta.ko
filename:       /lib/modules/rt2870sta.ko
version:        2.1.2.0
license:        GPL
description:    RT2870 Wireless Lan Linux Driver
author:         Paul Lin <paul_lin@ralinktech.com>
srcversion:     9DE967CDFD2CF4D29A43326
alias:          usb:v050Dp815Cd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0411p00E8d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v1737p0071d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v1737p0070d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v7392p7717d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v7392p7718d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v5A57p0282d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v5A57p0280d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v04E8p2018d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v14B2p3C09d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v1482p3C09d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v050Dp805Cd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v157Ep300Ed*dc*dsc*dp*ic*isc*ip*
alias:          usb:v129Bp1828d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0E66p0003d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0E66p0001d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v15C5p0008d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v083Ap6618d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v13D3p3247d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v14B2p3C25d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0471p200Fd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v1740p9702d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v1740p9701d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0CDEp0025d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0586p3416d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0CDEp0022d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v083Ap7522d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v083Ap8522d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v083ApA618d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v083ApB522d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v15A9p0006d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v1044p800Bd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v07AAp003Fd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v07AAp003Cd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v07AAp002Fd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v14B2p3C27d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v14B2p3C23d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v050Dp8053d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v14B2p3C07d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v07D1p3C11d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v07D1p3C09d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v2019pED06d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v14B2p3C28d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v14B2p3C06d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0DF6p002Dd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0DF6p002Cd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0DF6p002Bd*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0DF6p0017d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0B05p1742d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0B05p1732d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0B05p1731d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v177Fp0302d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0789p0164d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0789p0163d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0789p0162d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v083Ap7512d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v0DF6p0039d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v07B8p2770d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v07B8p2870d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v148Fp2870d*dc*dsc*dp*ic*isc*ip*
alias:          usb:v148Fp2770d*dc*dsc*dp*ic*isc*ip*
depends:
vermagic:       2.6.33-5-sigma preempt mod_unload MIPS32_R2 32BIT
parm:           mac:rt28xx: wireless mac addr (charp)
Server HW: Xeon CPU E3-1270, 16GB RAM, 9TB Raid-Z + L2Arc,
Server SW: Ubuntu 12.04 x86_64, ZFS on Linux, Java 1.6.0_21, SageTV 7.1.9.1
Tuner HW: Pinnacle 800i, Pinnacle 801e USB, HDHR
Client: HD300, HD100
Old 03-02-2011, 05:03 PM
tmiranda's Avatar
tmiranda tmiranda is offline
The only downside of the Sage adapter is that it only supports 2.4 GHz, no 5GHz
Old 03-02-2011, 08:20 PM
Thanks to all that replied. I understand the technical requirements for using one of the two recommended usb adapters. Here's my complaint though. First, I don't think the requirement is spelled out in requirements for the HD 300. It does not state that you must use one of the two adapters. That's a marketing problem. Second, the cost. I just spent $29.95 for the adapter and almost half for shipping ($14.49). I'll have to wait a week to recieve the adapter because SageTV can't ship any more efficiently (I purchase from NewEgg, also in California, and it takes about two days and does not cost $14.49 per shipment). I hope support is more efficient when I need it.
Old 03-02-2011, 09:01 PM
rrhorer rrhorer is offline
You can get the adapter that works from NewEgg. I did.
unRAID Basic Server, Sage & OpenDCT Dockers, Core i3-8100, 8G Memory, HDHR Prime, HD300 Extender, Shield & Android Miniclient, Harmony Hub/Remote
HD300 NO wireless but HD200 wireless works jbmoore99 SageTV Media Extender 0 02-01-2011 05:34 PM
HD300 Wireless Issues RetroBox SageTV HD Theater - Media Player 21 01-30-2011 03:00 PM
HD300 wont' access videos via SageTV icon getgray SageTV Media Extender 4 01-29-2011 08:44 PM
Wireless Access Points that work with MVP Chad Hardware Support 4 09-25-2006 12:15 AM
