Old 08-04-2014, 01:58 PM
jbuszkie's Avatar
jbuszkie jbuszkie is offline
Web BMT doesn't load...
Sometimes when I try to run the web BMT it doesn't work.
I get:
Directory: /bmt/
WEB-INF/ 0 bytes Jul 18, 2014 8:26:34 PM
If I restart Sage then it works fine again for a while.
How can I debug this? I'm tired of restarting sage all the time! Grr...
Jim
Old 08-05-2014, 03:51 PM
I have the same problem.
I am running SageTV as a service, so I just stop and start the service and it clears the problem.
Tuner: (2) HDHomeRun Prime
Client: (2) HD300
Client: Mini-Client, ShieldTV
Client: Mini-Client, Fire TV Stick 4K
Old 08-05-2014, 03:54 PM
jbuszkie's Avatar
Yeah.. That's what I do too.. But sometimes something is recording when I want to use BMT! I'm hoping for a way to fix it without restarting the service!
Jim
Old 08-05-2014, 03:55 PM
jbuszkie's Avatar
But it's good to know I'm not the only one.
Jim
HD PVR doesn't record entire program (doesn't lock up either) lakerrush Hardware Support 0 06-13-2009 09:41 AM
Got HD-PVR, remote doesn't work (new irremote.ini doesn't fix) nightlyraver Hardware Support 1 03-31-2009 04:29 PM
CPU Load KipKasper SageTV Software 3 03-30-2009 10:34 PM
Re-ordered frq file doesn't load in SageTV cortechs SageTV Software 2 01-14-2007 11:51 AM
Won't Load justlearnin SageTV Beta Test Software 3 08-13-2003 12:56 PM
