Old 10-22-2015, 07:23 PM
mayamaniac's Avatar
HD300 IR port not working
I hid my HD300 out of line of sight, so I plugged an IR reciever into the front IR port, but it doesn't work. It doesn't respond to any remote commands.
I also tried it with a different IR receiver and a different HD300, neither worked. Any ideas why they aren't working. The red light on the IR receiver does come on when plugged in.
Mayamaniac
Old 10-22-2015, 08:34 PM
Are you using the IR receiver that came with the HD300. If not there is a thread some where that tells you how to wire one to work with the HD300. Look through this thread
http://forums.sagetv.com/forums/showthread.php?t=56246
Old 10-22-2015, 11:34 PM
mayamaniac's Avatar
I did buy it, but I actually never used it so I forgot what it looks like. I took all the IR receiver I could find and neither of them worked. I guess they ain't the right ones but I thought they are all standard IR receivers, didn't know there are different kinds.
Anybody wanna donate a spare orginal IR receiver?
Mayamaniac
Old 12-31-2015, 10:53 AM
I know this thread is kinda old ... but one thing I found out that works great is the flirc .. It even works better than the built in IR receiver as it can use any remote. You just need to setup the keystrokes and program the flirc on any PC then just plug it into the hd300... or hd200.
Latest HD300 Beta FW Killed Network Port HavaCuppaJoe SageTV Beta Test Software 5 02-22-2011 12:06 AM
HD300 has 10/100 ethernet port, not gb? mayhewda SageTV Media Extender 8 09-03-2010 03:02 PM
SageTV Not Opening Com Port (Using Digi realport multi-port serial adapter) personalt Hardware Support 0 06-09-2010 07:02 PM
DirecTV Serial Port Control Just Stopped Working jsiemon Hardware Support 4 02-12-2008 04:33 PM
