Old 11-24-2016, 01:04 AM
ASegredo ASegredo is offline
Need Help Linux 9.0.9.483
When I execute /etc/init.d/sagetv start, opensagetv dies. Inside it I set -x to see where it dies. It seems to be the java call. I am java illiterate and need further help finding out why it dies.
X3 opensagetv # /etc/init.d/sagetv start
Starting SageTV Server: sagetvChanging to SageTV directory /opt/sagetv/server
+ exit 0
+ ./startsagecore
Executing pre-scripts
Starting server mode
+ javapid=29136
+ echo -n 29136
+ wait 29136
++ echo 'JARs/*.jar'
++ sed 's/ **/:/g'
+ java -Djava.awt.headless=true -Xmx768m -XX:+UseAdaptiveSizePolicy -XX:MaxGCPauseMillis=25 -XX:GCTimeRatio=24 -XX:ThreadPriorityPolicy=1 -cp 'Sage.jar:.:/:JARs/*.jar' sage.Sage 0 0 x 'sagetv Sage.properties'
Main is starting
+ '[' -e restart ']'
+ '[' -e restartsvc ']'
+ '[' 0 -eq 1 ']'
+ exit 0
Old 11-24-2016, 05:12 AM
Do you have java installed? Which java? Version?
Old 11-26-2016, 05:42 PM
1.8.0.60 I tried to download later versions but it wouldn't allow them to be downloaded to my country (USA).
Old 11-27-2016, 05:49 AM
What do you get when you issue
java -version
Also, when you restart linux, sagetv should start automatically. if you open a terminal and issue
ps aux | grep sage
Do you see the sagetv process?
What linux flavour are you using? And how did you install sagetv?
If you want to avoid the configuration of sagetv on Linux, you might check out the docker solution as well. While it was originally created for unRAID NAS (which is what I use), you can also use it to run sagetv locally as well... just requires that you know a bit about docker.
Old 11-28-2016, 10:18 AM
tony@X3 ~ $ java -version
java version "1.8.0_112"
Java(TM) SE Runtime Environment (build 1.8.0_112-b15)
Java HotSpot(TM) 64-Bit Server VM (build 25.112-b15, mixed mode)
(i finally managed to download it)
tony@X3 ~ $ ps aux | grep sage
message+ 2595 0.0 0.0 17760 2316 ? Ss Nov23 0:00 /usr/bin/dbus-daemon --system
tony 25358 0.0 0.0 12936 1864 pts/1 S+ 10:10 0:00 grep --colour=auto sage
This is Gentoo Linux. I installed by following the instructions to install on Ubuntu on a UBUNTU partition. Then I copied the files to the Gentoo system. It doesn't seem to be working on UBUNTU either. The TV card is an HVR-1600 and I can use azap to tune it and mplayer /dev/dvb/adapter0/dvr0 to watch TV.
Old 11-28-2016, 10:36 AM
I doubt this is a java issue... since you installed it, and it works. But maybe try starting sagetv directly (without the init script) and then see how it dies, and check the sagetv_0.txt log file to see what it says.
Old 11-28-2016, 10:41 AM
The installer does more than just copy files around. There are a lot of permissions, and scripts that are setup. It will likely be a lot of work to get going if you don't just use the installer script on the system you are installing it on.
Old 11-28-2016, 02:42 PM
OK! Running the java statement straight gives an error message:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no Sage in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1867)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at sage.Sage.<clinit>(Sage.java:115)
Old 11-28-2016, 02:45 PM
Mon 11/28 10:07:36.409 [main@37bba400] MAIN THREW AN EXCEPTION: java.lang.NoClassDefFoundError: org/apache/lucene/search/Query
Mon 11/28 10:07:36.410 [main@37bba400] java.lang.NoClassDefFoundError: org/apache/lucene/search/Query
Mon 11/28 10:07:36.411 [main@37bba400] at sage.SageTV.<init>(SageTV.java:404)
Mon 11/28 10:07:36.411 [main@37bba400] at sage.Sage.startup(Sage.java:1173)
Mon 11/28 10:07:36.411 [main@37bba400] at sage.Sage.main(Sage.java:955)
Mon 11/28 10:07:36.411 [main@37bba400] Caused by: java.lang.ClassNotFoundException: org.apache.lucene.search.Query
Mon 11/28 10:07:36.411 [main@37bba400] at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
Mon 11/28 10:07:36.411 [main@37bba400] at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
Mon 11/28 10:07:36.411 [main@37bba400] at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
Mon 11/28 10:07:36.411 [main@37bba400] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Mon 11/28 10:07:36.412 [main@37bba400] ... 3 more
Mon 11/28 10:07:36.412 [main@37bba400] Exception in thread "main" Mon 11/28 10:07:36.412 [main@37bba400] java.lang.NoClassDefFoundError: org/apache/lucene/search/Query
Mon 11/28 10:07:36.412 [main@37bba400] at sage.SageTV.<init>(SageTV.java:404)
Mon 11/28 10:07:36.412 [main@37bba400] at sage.Sage.startup(Sage.java:1173)
Mon 11/28 10:07:36.412 [main@37bba400] at sage.Sage.main(Sage.java:955)
Mon 11/28 10:07:36.412 [main@37bba400] Caused by: java.lang.ClassNotFoundException: org.apache.lucene.search.Query
Mon 11/28 10:07:36.413 [main@37bba400] at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
Mon 11/28 10:07:36.413 [main@37bba400] at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
Mon 11/28 10:07:36.413 [main@37bba400] at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
Mon 11/28 10:07:36.413 [main@37bba400] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Mon 11/28 10:07:36.413 [main@37bba400] ... 3 more
Old 11-28-2016, 03:06 PM
I think this goes back to Fuzzy's comment... i don't think this is installed correctly.
Did you download the tgz bundle? This is a 64bit bundle... are you running 64bit?
Have you considered using ubuntu (there is a .deb package), or Docker... there's a complete ready to run Docker container...
But, as it stands, given the errors you are reporting... I don't think there files are installed correctly.
Old 11-28-2016, 04:49 PM
I downloaded the .deb and installed it on Ubuntu. Maybe the Ubuntu version was too old?
Where is the installer? I ran the buildscripts. Is that what's referred to.
I prefer not to use Ubuntu with that Windows 8 interface.
Old 11-28-2016, 06:51 PM
I think most who are running the server on linux don't even have a monitor, so the UI is pretty much a moot point (I just used the ubuntu server version before switching to unRAID).
Old 11-29-2016, 12:46 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
From those error messages it looks like the libSage.so file is not in the LD_LIBRARY_PATH. This should be getting set properly in the startsagecore script (which is called by startsage) and should be in the same folder as that script (or in a lib subfolder, but I don't think the installer puts it there).
The other error messages relating to Apache would point to the lucene-core-x.x.x.jar file not being in the JARs subfolder below the startup script.
Maybe the permissions on all of them are wrong?
And the installers are either the tarballs (.tgz) or debian installers (.deb) that are created in the build folder when you build the whole project.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 11-29-2016, 08:25 PM
Thank you, Narflex
/opt/sagetv/server/startsagecore
/opt/sagetv/server/libSage.so
So they are in the same directory.
/opt/sagetv/server/sagetv/third_party/Lucene/lucene-core-3.6.0.jar
Is that the wrong place for the jar?
Old 11-29-2016, 08:37 PM
I copied the lucene jar:
# cd /opt/sagetv/server
cp /opt/sagetv/server/sagetv/third_party/Lucene/lucene-core-3.6.0.jar JARs/
This time, some progress.
# java -Djava.awt.headless=true -Xmx768m -XX:+UseAdaptiveSizePolicy -XX:MaxGCPauseMillis=25 -XX:GCTimeRatio=24 -XX:ThreadPriorityPolicy=1 -cp Sage.jar:.:/:JARs/lucene-core-3.6.0.jar sage.Sage 0 0 x 'sagetv Sage.properties'
Also noted this is kern.log (a good sign, yes?)
Nov 29 20:24:57 X3 kernel: cx18-0: loaded v4l-cx23418-cpu.fw firmware (158332 bytes)
Nov 29 20:24:58 X3 kernel: cx18-0: loaded v4l-cx23418-apu.fw firmware V00120000 (141200 bytes)
Nov 29 20:24:58 X3 kernel: cx18-0: FW version: 0.0.74.0 (Release 2007/03/12)
Nov 29 20:24:59 X3 kernel: cx18-0 843: loaded v4l-cx23418-dig.fw firmware (16382 bytes)
Nov 29 20:24:59 X3 kernel: cx18-0 843: verified load of v4l-cx23418-dig.fw firmware (16382 bytes)
Nov 29 20:25:01 X3 kernel: tda18271: performing RF tracking filter calibration
Nov 29 20:25:05 X3 kernel: tda18271: RF tracking filter calibration complete
Old 11-30-2016, 06:45 AM
I'm still stuggling with how this would have been installed... did you build the .tgz package (which is created from the buildall.sh) and then extract it into /opt/sagetv/, if not, then that is likely your issue. There are many native parts to sagetv and even the lucen jar should not need to be manually copied to the JARs folder... that should all be packaged in the right places in the .tgz package.
Also are you using the startsage script to the startsagecore? You should use startsage.
Old 11-30-2016, 01:00 PM
Narflex's Avatar
Sage
Yeah, I'm with Stuckless on this one...it definitely looks like you didn't extract the tgz file into the target folder and were just copying files (or you're trying to run it from where it was built, which also won't work properly)
Jeffrey Kardatzke
Google
Founder of SageTV
Old 11-30-2016, 01:18 PM
Originally Posted by stuckless View Post
Idid you build the .tgz package (which is created from the buildall.sh) and then extract it into /opt/sagetv/,
Yes, I built on Ubuntu, copied the tgz to Gentoo and extracted it. As I mentioned, it doesn't run on UBUNTU, either. Perhaps the Ubuntu version is too old. A months ago, I tried building on Gentoo but a lot of paths are different and library versions not the same. I was told "it builds on Ubuntu" so I went that route.
I started that way, but had to run java directly to get the error messages, otherwise it dies silently.
Old 11-30-2016, 01:31 PM
ok lets try this...
cd /opt/sagetv/
rm sagetv_*.txt
./startsage
That should setup paths, LD environment, etc... and try to start sage.
You an tail sagetv_0.txt to see if it's starting...
you can look in nohup.log (I think we sagetv starts in the background it write stdout to that file, or similarly named fie, in the current directory).
also, run it as root.
If you are running just the java command iine, then that won't work.
Old 11-30-2016, 08:50 PM
# ./startsage
Changing to SageTV directory /opt/sagetv/.
./startsage: line 53: ./startsagecore: No such file or directory
copied startsagecore to /opt/sagetv
cp /opt/sagetv/server/startsagecore /opt/sagetv
Wed 11/30 20:35:21.962 [main@3796751b] Exception in thread "main" Wed 11/30 20:35:21.962 [main@3796751b] java.lang.NoClassDefFoundError: jcifs/smb/SmbException
Wed 11/30 20:35:21.962 [main@3796751b] at sage.SageTV.<init>(SageTV.java:509)
Wed 11/30 20:35:21.962 [main@3796751b] at sage.Sage.startup(Sage.java:1173)
Wed 11/30 20:35:21.962 [main@3796751b] at sage.Sage.main(Sage.java:955)
Wed 11/30 20:35:21.963 [main@3796751b] Caused by: java.lang.ClassNotFoundException: jcifs.smb.SmbException
Wed 11/30 20:35:21.963 [main@3796751b] at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
Wed 11/30 20:35:21.963 [main@3796751b] at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
Wed 11/30 20:35:21.963 [main@3796751b] at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
Wed 11/30 20:35:21.963 [main@3796751b] at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
Wed 11/30 20:35:21.963 [main@3796751b] ... 3 more
Comcut + encoding for linux, a start to a linux mediastrink Korny SageTV Linux 1 03-13-2011 09:57 PM
Close to building a Linux SageTV Computer, which Linux distribution is best? davephan SageTV Linux 8 02-24-2011 06:57 PM
Possible new Linux box waynedunham SageTV Linux 0 11-16-2006 04:53 PM
New to linux bowser700 SageTV Linux 2 08-17-2006 09:13 AM
