Android TV box 4K for $65
I know nothing about this box, but at $64.99 it might be worth checking out. These are usually limited time specials...
VicTsing Android 5.1 TV Box Carry Rockchip 3368 Octa Core Cortex-A53 & 64 bits CPU H.265 Decoding Gives You True UHD 4Kx2K Resolution@60 fps Support XBMC KODI http://www.rakuten.com/prod/-newest-...287791700.html |
Fyi this isn't truly running android tv. It's a box running regular android that you can hook up to your tv.
I've read reviews of these boxes on other forms, and they have been pretty negative. The software is extremely buggy and the support is nonexistent. I decided it was not something I wanted to waste my time on.
Thanks for the feedback. I'll give it a skip...
OK android TV box? | MattHelm | General Discussion | 2 | 11-17-2015 11:41 PM |
Android TV | 7up | General Discussion | 46 | 01-08-2015 03:13 PM |
For Android developers... | Fonceur | SageTV v7 Customizations | 1 | 12-17-2012 05:19 AM |
Android ported to .Net | bcjenkins | The SageTV Community | 6 | 05-06-2012 05:26 PM |
DIY Android STB: NeTV | KJake | The SageTV Community | 0 | 12-20-2011 11:15 AM |
