Old 11-17-2004, 06:29 PM
dvd_maniac's Avatar
dvd_maniac dvd_maniac is offline
Help with compression
I have searched for info on setting compression up and the more I read the more confused I seem to get.
I am using the CayarsV21E stv and I am wondering if someone could help me out in setting it up? I would really appreciate it.
Old 11-18-2004, 12:21 PM
Crashless's Avatar
Sorry, I've been meaning to reply here, but work has been very crazy.
Lets start at the begining - what format do you want to go to?
Old 11-18-2004, 02:10 PM
jdbrown's Avatar
jdbrown jdbrown is offline
I'm in the same boat. Where can I find out what format options are even available? Thanks.
OS: XP Pro SP2 Case: Ahanix D.Vine 4 with Zalman ZM300B PSU Case fans: 2 x SilenX 60mm Mobo: Intel D865PERLL
CPU: P4/3.0EGHz 800M 478P/1MB HT CPU cooler: ZALMAN CNPS7000A-CU RAM: 512MB Corsair XMS Extreme DDR400 Video: Sapphire ATI Radeon 9600 256MB 128bit 8XAGP Tuner: Hauppage PVR-250MCE HD: Seagate 7200 200GB, Maxtor USB2 120GB Optical: STB: DishNetwork VIP211 TV: Sony WEGA KV-36FS100 (s-video) Apps: SageTV 4.0.0.56 w. Hotspot JVM 1.5.0_02,
Remote: MX-500 with USB-UIRT and Girder
Old 11-18-2004, 02:33 PM
dvd_maniac's Avatar
I would like to go Divx, but would try other formats if they are easier/more reliable.
And I (and I bet many others) would really appreciate the help...
Old 11-18-2004, 03:09 PM
Crashless's Avatar
Ok then. You could try picking up where I left off from these two posts:
http://sage.tv/forums/showpost.php?p...&postcount=121
http://sage.tv/forums/showpost.php?p...&postcount=149
I'm still using dubman for my script, but another user, Broca, got Virtual dub to work straight through the command line, without dubman.
http://sage.tv/forums/showpost.php?p...&postcount=270
I haven't been able to get that part to work though. So if you give it a try, let me know via PM.
Sorry I can't be more detailed right now. Deadlines suck.
