Old 03-21-2010, 06:58 PM
SageGk SageGk is offline
Recordings showing up in videos?
Some Sage recordings are showing up in my "Videos" media center. It is cluttering my Videos section and I can't figure out how to fix this. My settings are correct (for my selected video folders) so I don't know why the recordings are showing up. Anyone? Thanks
Old 03-22-2010, 10:38 AM
The only "normal" reason a recording would be imported instead of recognized as a recording would be if SageTV lost track of what the file is.
What customizations are you using? Are any of them messing with the filename and/or metadata for your recordings?
Have you recently changed something & reverted to an older wiz.bin or even started using a new one?
Have you renamed any of the recordings' files or tried to manually move them w/o following the recommended method of moving recordings listed in a FAQ at the top of this forum?
Old 03-27-2010, 05:39 PM
Thanks, I just deleted them all manually. I think it may have been a result of reinstalling Sage a while ago.
Old 05-30-2010, 01:08 PM
BKeadle BKeadle is offline
I'm seeing this in my collection now. I might have done one or more of the items you suggested Opus. But, now how do I fix/clean it up?
Old 05-31-2010, 06:57 AM
I got this sorted out. I moved the files out of the Import directory, then did a rescan. I then moved the files back to the logical locations, then did a rescan again, and now things are where I want them to be.
However, this effectively deleted the recordings out of the database, then re-added them - but any previous metadata would now be gone. To avoid losing this information when I attempt this cleanup, is that what the .my files might be able to preserve for me? How do I generate .my files for recordings?
Sage Recordings Showing in Imported Videos jsonnabend SageTV Software 15 10-18-2009 08:50 AM
Recordings showing up in my Imported Videos LazyGun SageTV Software 9 04-09-2009 08:30 AM
Why are my recordings showing up under videos? rdefino SageTV Beta Test Software 3 05-22-2008 08:51 AM
Imported recordings not showing in recordings when named correctly, worked in 6.0 Robsters SageTV Beta Test Software 4 02-21-2007 10:58 PM
Moving Sage-recorded Videos from Imported Videos to SageTV Recordings esims21 SageTV Software 1 02-05-2005 11:32 AM
