Old 12-16-2005, 11:56 AM
JUC's Avatar
JUC JUC is offline
MVP AR settings
Does the Aspect Ratio settings now work with the MVP extender? That would be great.
Also, was the problem fixed where the picture gets offset to the right 1-2"? edit: Opus, I think you also had this problem with the MVP in the past?
JUC
Old 12-16-2005, 12:11 PM
AR settings are not configurable on an MVP.
I don't think the video gets shoved off the right side any more; if it does, I haven't seen it. It seems to fairly closely match the picture that my xcard shows.
Old 12-16-2005, 12:16 PM
JUC's Avatar
JUC JUC is offline
andy thanks, jeff just responded in another thread that the issue with the picture not being centerred properly is fixed now. Good to hear.
JUC
