Old 03-22-2006, 09:35 AM
alijiwani alijiwani is offline
Getting 5.1 DVD Audio in Sage?
I looked around for a post addressing this and could not find anything useful.
I have Sage 4.1.9 and an Audigy EX Platinum connected to a H/K Receiver via both optical out and 5.1 analogue.
Sage only gives me 2ch audio no matter what I mess with. I tried changing the DVD decoder, didnt seem to help. To get 5.1 audio, I have to usee WinDVD alone with passthough on.
Any thoughts on what I can do here?
thanks
-ali
SageTV 6.5.4+Webserver 2.21+SageMC 6.3.8a, P4-2.8 Ghz, 1GB RAM, 120GB HD, 1.5TB HD, 500GB HD, PVR-150, PVR-350, AverMedia A180, ATI x1600 512MB AGP, Audigy Platinum EX, connected to an Sony 46XBR6 LCD via DVItoHDMI and Sony STR-DA2400ES receiver via 5.1 analog.
Old 03-22-2006, 11:21 AM
I replied in the other thread but let me elaborate a bit on my personal hatred of Intervideo.
They, in their infinite wisdom, have made their decoders such that the settings from the WinDVD app, aren't applied to the decoders in 3rd party apps. Further, if you can get into the decoder properties, and change them the settings aren't saved.
What you have to do is dig through the registry and find where WinDVD stores the settings, and then find the key for the app you're using (SageTV in this case). Yup that's right, Intervideo stores different settings for each app. That might not be bad, but they don't generate them from your present settings they go back the the default settings for new apps, so you have to dig through the registry for each and every app you use.
Long story short you need to set a couple of dwords (I think AUDIO and/or AUDIOCHAN) to the right value and then you'll get S/PDIF passthrough from apps other than WinDVD.
Old 03-23-2006, 09:45 AM
thank you!!
Old 03-23-2006, 04:38 PM
Polypro Polypro is offline
Stanger, that doesn't work for DNM though, does it? (The one v6 build is the only way I've seen DNM working outside of WinDVD).
P
Old 03-23-2006, 04:47 PM
No, they seem to have pulled DNM out of the Directshow filter.
