April Update - Now No USBUIRT Tuning
So my Sage server just ran the April 2018 update.... Post update, now my USBUIRT isn't tuning the channels on my Sat receivers. I still see it in the list of USB devices... Anyone else run into this? My HDPVRs are recording - just not from the right channels...
Tnx -Steve
Server: Win 10 Pro 64 Bit, Intel i5, 8 GB, Samsung EVO 850 500 GB for OS, WD Black 4 TB + WD Black 1 TB for Recordings, 36TB Synology 1019+ for DVD/Bluray Rips, Music, Home Movies, etc., SageTV Server 64 Bit Ver 9.2.6.976, HDPVR x 2, Bell TV 6131 Receiver x 2, USB-UIRT with 56 KHz Receiver Clients: PC Client x 2, HD-300 x 2 (1 Using Netgear MoCA Coax Bridges), SageTV Miniclient on NVidia Shield x 3 |
Resolved
Problem seems to have fixed itself, whether due to the rest of the updates, or the 2 or 3 reboots associated with them...
I have a USBUIRT that I originally was using when I had a single STB and no FireWire port. But when I went to 2 STBs (and HD-PVR's naturally) I upgraded to a MOBO with FW ports and the tuning was flawless on both STBs for years. When I was considering going back to the USBUIRT several things I read said it didn't work with Win8/10 and looking at their website the drivers hadn't been updates in MANY years. So I thought it was a non-starter and went with a 32 bit Windows OS so I could keep my FireWire STB tuning. If people have working USBUIRT setups with Win10 64 bit I may try to make the move and use my USBUIRT for tuning. Being able to use 64Bit Java would probably help IMMENSELY with all the Java heap overruns I get in the 32 bit Java. Usually at least once a day on my main server and less frequently on my old backup server since it gets used for viewing so little. I just point my SageTV extender to the old backup machine to delete watched shows and make sure it is recording the right things.
Wayne Dunham |
Remember, any 32-bit version of Windows can only access a max of 3GB of memory. The OS + app(s) must all fit in that 3GB memory space. The Win7/8/10 OS itself eats about 1GB of that, leaving typically only 2GB for all applications. Pretty restrictive. On the other hand, running a 64-bit version of Win7/8/10 means that any single 32-bit app **itself** can access up to a max of 4GB. While not massive, that's still a pretty big improvement as far as Sage is concerned. Under these conditions, it's possible to bump the Java Heap space up to 1GB. Personal experience with supporting 4 different Sage systems running on Win7-x64 (with 8GB of memory) has been that (with one exception), the system is very stable and easily runs for 6 months at a time without needing to restart Sage or the OS. Caveat: none of these systems have any Sage extensions installed, which can be fairly heap-hungry. My single biggest source of Sage instability used to be one system with 2 HD-PVR capture devices and 3 HD-200 extenders. After instituting a nightly power-cycle of the HD-PVRs, that system is also pretty stable now. It runs for months without needing to restart Sage or the OS.
System #1: Win7-64, I7-920, 8 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HDHR-US (1st gen white) tuners. HD-200. System #2: Win7-64, I7-920, 8 GB mem, 4TB HD. Java 1.8.0_131. Sage v9.1.6.747. ClearQAM: 2x HDHR3-US tuners. HD-200. System #3: Win7-64, I7-920, 12 GB mem, 4TB HD. Java-64 1.8.0_141. Sage-64 v9.2.1 ATSC: 2x HVR2250; Spectrum Cable via HDPVR & USB-UIRT. 3x HD-200. |
Sage 9 server = Gigabyte AMD quad-core - 4 gigs - integrated ATI HD4200 chipset - SSD boot, Hitachi Deskstar show drives. HD-PVR - Colossus - Win7 32 bit. HD200/300’s networked. HDHomerun tuner. "If you've given up on Weird Al, you've given up on life" - Homer Simpson |
Correct. That's the one disadvantage of moving from 32-bit to 64-bit Windows.
More than anything, if I knew how to write code for these kinds of things, I’d update that FireWire, 32bit thing to 64bit. Who was that guy and where did he go? I realize 1394 isn’t used as much these days, but my new, Cox, Cisco set top box still has one, and it still works. And it works very, very well...
I don't even know where the technical specifications for the messaging protocols live.
Server: i5 8400, ASUS Prime H370M-Plus/CSM, 16GB RAM, 15TB drive array + 500GB cache, 2 HDHR's, SageTV 9, unRAID 6.6.3 Client 1: HD300 (latest FW), HDMI to an Insignia 65" 1080p LCD and optical SPDIF to a Sony Receiver Client 2: HD200 (latest FW), HDMI to an Insignia NS-LCD42HD-09 1080p LCD |
No - it works perfectly fine on unRAID Linux which is 64bit and other Linux variations as well.
If Windows SageTV can't use 64bit at all then moving and setting up USBUIRT would be moot for me. I'm not really having any performance issues using 32bit Windows, it is just the constant Java Heap overruns where I have problems. Every time my main machine (which has more lineups) does an EPG update if fires off the Java Heap warning message (set at 90% and my Java Heap is maxxed out). Weird thing that happens just lately is that when this happens after an EPG update my recordings listings won't honor my settings. The "current recordings" aren't supposed to show archived recordings, but do. Once I restart the server and clear the Java heap problem they once again do not show under current recordings. There is another very short thread elsewhere about getting 64bit Java to work with SageTV Windows version. Narflex said something along the lines of as far as he know the code should work with 64 bit Java and suspected one or some of the compiled DLL(s) might be where the problem lies. Sure would be nice to get it working with 64 bit Java.
Wayne Dunham |
The problem is finding someone with the knowledge and time to do the work. One of the big problems with this project is the lack of active developers with institutional knowledge. I think there are a few devs that have gained enough knowledge about little bits and pieces of the code to make necessary small changes. Narflex is really the only one that has that kind of knowledge but he's not really active. People can keep using SageTV as-is but unfortunately I don't think things in the core are going to change much, if at all. With modern products like Plex making inroads into DVR territory SageTV doesn't look as good as it once did. Plex has, IMHO, a nicer interface built on modern web technologies and also supports hardware transcoding using Quick Sync. SageTV's web interface is pretty hard on the eyes and is built using old-school Tomcat server-side dynamic page building. Far from the efficient REST or GraphQL used today where the client builds its own interface based on data from the API server. Anyway, sorry, I'm rambling now. Got myself on a soapbox.
The latest version of the Plex UI actually includes chapter support. So it may not be that difficult to make use of that. They may be on the road to doing not-destructive commercial skipping. I've not been able to dig that far into Plex's DVR due to it still being kind of buggy but they already have a pretty good system of knowing what you have and haven't watched. I have done tests with it and my two HDHR's but I keep getting partial recordings where it just stops getting data and then Plex crashing between sequential scheduled recordings. I keep trying it though.
After channel lineup change, USBUIRT is tuning wrong channel | timg11 | Hardware Support | 1 | 08-28-2014 10:47 PM |
Potential reasons for USBUIRT not tuning accurately? | IVB | Hardware Support | 6 | 12-28-2009 11:51 AM |
Cayars Ultimate STV: Documentation v1.3 - April 7 | ajuhawk | SageTV Customizations | 17 | 10-25-2005 11:18 PM |
Tivo Remote, USBUIRT, and Sage USBUIRT support | mikejaner | Hardware Support | 2 | 10-28-2004 07:19 AM |
