Motorola DCH6416
Well i made the switch to Insight from DirectTV. Did it on a whim, but trying to figure out how to change channels. It looks like most are using either IR blaster or firewire. I see they have ethernet ports, but it doesnt look like they work.
I see tommoore's firewire drivers, but it looks like they only work on MCE. I tried installing and it imediately said it would not install on plain old XP. So the qestion of the day is, what is the best (or maybe only) way anyone has had succes with changing the channel on these dhc6416 boxes? Thanks! |
I belive in xp without MCE you have to install differently.
create a batch file with the below and put it where firestb.msi is and run it. msiexec /i firestb.msi IDENT=”1” or you can go here and just download the drivers. http://home.comcast.net/~exdeus/stbfirewire/ Then you can go here and setup Sage for channel changing. http://babgvant.com/files/folders/sa...ntry11740.aspx
Windows 10 I3 Dual Core 3.0 Server, SageTV9... OpenDCT with 2 HDHRPrimes and 4 HDHRconnects for a total of 14 Tuners. Last edited by nyplayer; 05-15-2011 at 12:31 PM. |
Thanks for the tips. trying it Monday. I'll let you know how it goes.
Wow! I never realized how badly firewire had fallen out of favor. You cant find these cables anywhere but microcenter in my area!
Motorola DCT2524 | laser2.x | Hardware Support | 1 | 05-15-2007 06:01 PM |
motorola QIP 2500-2 | jepalmer1391 | Hardware Support | 0 | 01-28-2007 10:44 AM |
Problem with motorola box over fw | badahab | Hardware Support | 0 | 11-13-2006 12:26 AM |
Motorola DCT2524 | Ram85 | Hardware Support | 7 | 02-15-2005 11:52 PM |
GI/Motorola | GrayGh0st | Hardware Support | 3 | 06-23-2004 07:52 AM |
