Old 04-10-2014, 11:54 AM
freewheeling's Avatar
freewheeling freewheeling is offline
Question about IP Tuning DirecTV
I've been successfully using IP tuning with my DirecTV box for some time. I mean, it's successful in the sense that I can reliably tune to the right channel. The problem is that in the mean time the box goes to sleep so that all I get when I tune the channel is the audio with that DirecTV logo floating around on a black background. I have to manually hit "select" on the DirecTV remote to get it to wake up and display the picture. Is there a way to turn off this sleep thing, or use the IP tuning to wake the box up?
Old 04-10-2014, 12:58 PM
jchiso jchiso is offline
Yes, and yes.
You can disable the Power-Saving features of the STB in the Settings menu. You can also send a keystroke command (such as Exit) to the receiver using a batch file or script that you use for tuning ...
Old 04-10-2014, 02:46 PM
Originally Posted by jchiso View Post
Yes, and yes.
Thanks. Power-Saving is turned off already. I guess I need to know how to set up the batch file.
Old 04-10-2014, 05:07 PM
Skirge01's Avatar
Skirge01 Skirge01 is offline
What model receivers are you using? I have an H21 and an H24, but with power saving disabled, I don't see this issue. Are you certain it's not something else? I've only seen the DTV logo when I wind up on a channel I don't receive or if the reception is lost for an extended period.
Software: SageTV 7
Old 04-10-2014, 08:27 PM
Looks like an HR24 which is part of the in-home system. It is clearly the screen saver that's kicking in, not the image that comes up when you tune to a channel you're not subscribed to. And energy saving is turned off. I need a way to send a "select" signal before I tune in a new channel, or else I have to do it manually every few hours, or switch back to doing it with the USB-UIRT.
Old 04-11-2014, 07:04 AM
I have an HR24 and I don't have this problem. I use HTTP tuning. I will look through the settings tonight.
Old 04-11-2014, 03:06 PM
This is the content of my *.ir file. Just the one line:
192.168.0.21 38000 411 4 10 10
The address is correct. I don't know what the other numbers mean.
Old 04-11-2014, 03:41 PM
Mine is the following but I was thinking about what the settings on the DirecTV box are.
File name:192.168.1.148.ir
192.168.1.148 38000 411 3 10 10
But I believe the 3 and 2 10s are from this screen:
Old 04-11-2014, 04:08 PM
I don't see anything besides the option you already mentioned on my H24-700. You might try setting it to be on then exiting back to watching screen then go back into settings and set it off again.
I have the following settings (that I can remember just having come up from basement) for other settings. They probably won't make any difference for you but I will list all that I remember any way on the off chance it does.
Hide duplicate SD channels in Guide:Yes
Native mode output
480p, 720p & 1080i resolutions selected
Dolby digital: yes
Channel Guide First
8 second timeout on channel guide
Hopefully those are close enough to the actual wording for you to find if you want to.
Old 04-12-2014, 10:07 AM
Skirge01's Avatar
I'm going to ask the dumb question, since--as an experienced IT professional--I only forget this step when troubleshooting my own issues : Did you reboot everything, including the STB?
Also, a thread I found.
Software: SageTV 7
Old 04-15-2014, 03:04 PM
I have, and have also changed all the settings recommended and am still getting the screensaver. Guess I'll have to go back to using the USBUIRT unless someone can come up with a solution.
Old 04-17-2014, 03:11 PM
Are you using an External Tuner plug-in? If not, then you should, and all you would need to do is add a command to clear the screen saver prior to issuing the tuning command ...
Old 04-18-2014, 09:55 AM
I could not get the EXEMultiTunerPlugin to work so used Ericvic's DirecTVTuner.dll instead. Is there an instruction set for it? I can't get the USBUIRT method to work or it works only intermittently, so I may have to try the EXEMultiTunerPlugin again.
Update: Have installed the plugin, but I don't know how to send a clear screen command. Is this done in the options menu?
Old 04-19-2014, 03:12 PM
wbarber69's Avatar
wbarber69 wbarber69 is offline
Send a message via ICQ to wbarber69 Send a message via AIM to wbarber69 Send a message via MSN to wbarber69 Send a message via Yahoo to wbarber69
Since no one else has asked this. How many STBs and tuners are u using. You have to change settings for every STB. Not just the main WHDVR
Old 04-19-2014, 07:17 PM
OK, not having any idea what else to do I changed the *.ir file associated with DirecTV Tuning to the following:
192.168.0.21 38000 411 4 10 10 Select
Select 0 0 00 0a 72 2f 2e 2e 17 17 17 17 2e 17 17 2e 17 2e 2e 2e 2e 17 17 49
I got the line defining the "Select" command from the IR file that was created for the USBUIRT command set that I created using the old DirecTV IR remote. I will give it a few days to see if it works to turn the screensaver off when the channel is tuned. Of course I have no idea whether this is the correct definition of the "Select" command for IP Tuning, but it works what the heck? I does seem to change the channel OK with that file definition.
What is DirecTV IP tuning? freewheeling Hardware Support 1 03-14-2014 06:02 AM
Serial Tuning DirecTv Steve52 Hardware Support 7 02-23-2012 02:16 PM
Tuning in a non-HD DirecTV channel on a H20 BFisher Hardware Support 2 05-22-2008 09:47 AM
DirecTV Tuning Problem mayamaniac Hardware Support 29 01-13-2006 09:12 PM
Directv serial tuning? robk SageTV Beta Test Software 17 09-18-2005 10:17 AM
