Old 07-03-2007, 06:58 AM
DRAK's Avatar
DRAK DRAK is offline
Exclamation 6.2.4-SagetvService:timeout,failed to start
just noticed this when a server reboot failed to allow mvp connection!
in event viewer:
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7009
Date: 03/07/2007
Time: 13:30:58
User: N/A
Computer:
Description:
Timeout (30000 milliseconds) waiting for the SageTV service to connect.
THEN
Event Type: Error
Event ID: 7000
Date: 03/07/2007
Time: 13:30:58
User: N/A
Computer:
Description:
The SageTV service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
not a biggie for me as i leave server on 24/7, so i can start it manually but if there was to be an automatic restart i would be stuffed
any ideas?
Headless Server:Win7|8GB|i3-2100|Intel320-SSD|12Tb Storage|Colossus|Cinergy-2400i|Htvc STB|NAS 3Tb|1xPlaceshifter|1xHD200|2xHD300.
Old 07-04-2007, 05:29 AM
DRAK's Avatar
nobody else having this problem i take it?
things i've tryed are,
increase services timeout to 60000 ms
interact with desktop
log on as admin
Still no luck
Old 07-04-2007, 08:10 AM
log on as admin
Still no luck
Is this on XP or Vista?
Try going into the actual services on the machine and setup your user and password from there instead of through the Sage service control app. You should get a dialog box after sucessfully logging in that the user can now use the service or something like that.
Old 07-04-2007, 09:32 AM
DRAK's Avatar
it's on win2k3.
Thanks for the suggestion but i already tried all combinations with sage app
and through windows services. it starts manually ok just not automatically at
restart.
Old 07-04-2007, 10:28 AM
I've seen this too, on a cold boot. Service starts fine if you do it manually, but doesn't seem to go if Windows tries to kick it off on bootup. Oh, and Server 2k3 here.
Wonder if it has anything to do with WHS? Supposedly that's 2k3 based, and both of us are on 2k3.
Old 07-04-2007, 10:36 AM
DRAK's Avatar
Not just me then.
Does it on warm boot too!
Mabe some setting they changed to accommodate whs
BTW. was perfect on 6.1.
Old 07-07-2007, 05:03 AM
bones5050 bones5050 is offline
Drak,
I'm having the same problem too. I'm running Vista Home Premium. The service seems to timeout on startup, but will start normally if I start the SageTV service manually.
Old 07-07-2007, 06:44 AM
Just a quick update. This is a problem with the beta. I just reinstalled version 6.1.9 and the SageTV service starts up with no problem on a cold boot.
Old 07-07-2007, 04:49 PM
DRAK's Avatar
Update
I submitted a bug report and i was told to try my sagetvService.exe from 6.1 which work. Thanks Sage.
I was given a modified SagetvService.exe and that also worked.
So I think they know what the bug is and will get it fixed
I have attached the modified file if anyone either does not have there previous version or just wants it.
Old 07-09-2007, 05:48 PM
Nadim Nadim is offline
I am having the same problem on Windows XP Profesional. Will try to see if this file fixes the problem
Old 07-10-2007, 11:28 AM
navels navels is offline
This fixed the problem for me, thanks.
Lee
Old 07-11-2007, 06:05 AM
DIBU's Avatar
DIBU DIBU is offline
it's on win2k3.
restart.
well i have the beta version now tested here on my 2003 server...yes the service will not start auto. on startup, when i reboot the server (patch day) the sagetv service will not start.
Sage V7x:
Server - Lenovo K320 with WindowsHomeServer2011, 10 Terabyte HD's on stablebit drivepool, (1 x DuoFlex CT Octopus PCIe DVB-C 4 Tuner all with LM-DVB-SmartRecorder, dbox2, run SageTV as Service, DeskNow Mail and Collaboration server, 2 Terabyte NAS (Ximeta) as seconf backup, 1Gb/s MSI ePower HD Network, 3xHD100, 1xHD200, 1xHD300, Panasonic LCD 55" TV, Sharp LCD TV, JVC LCD TV, Touchscreen LCD, PlaceShifter
cu at http://www.dbuschek.de
recordings start delayed by ~5 minutes? Zarniwoop SageTV Software 25 07-16-2008 06:34 PM
Sage won't start Cleveland1 SageTV Software 12 01-29-2007 09:18 PM
Can't run service as my Win username: "service did not start due to a logon failure" jklenk SageTV Software 11 05-05-2006 05:43 PM
sagetv service won't start sedrum SageTV Software 7 01-24-2006 04:36 PM
Q: Can't start Sage, but can start KDE laurenglenn SageTV Linux 4 01-16-2006 06:28 PM
