Old 12-10-2007, 10:32 AM
John@TunerUK John@TunerUK is offline
Hauppauge 45 button remote. Some buttons not working.
I have the nova t 500 with the supplied 45 button remote, and I can only get the skip forward #2 button to work once. After that it does nothing. If I go to check the IR inputs in the detailed setup, that particular button on the remote is showing up as a CTRL command. If I then delete that button from the setup, and then re-map it, the button will work once, but then never again.
Also, the red button opens the hauppauge wintv program instead of it's propper use in sagetv.
At first I thought it was because the WinTV IR reciever program was running in the taskbar, but when I tried closing this, SageTV wouldn't work at all.
I'm out of ideas, anyone else got any?
Old 12-10-2007, 10:59 AM
If that tuner is still using the "regular" Hauppauge remote (as opposed to an MCE remote or something else), see this FAQ and/or my sig lines.
MCE Remote - Some buttons not working GTwannabe Hardware Support 4 07-25-2011 01:46 AM
Hauppauge 45 button remote issue (MCE kit remote) jlowery7 Hardware Support 12 04-16-2006 11:45 AM
TV Buttons For Remote Question mike1961 Hardware Support 4 04-06-2006 07:54 AM
MCE Remote : some buttons not working LostInSpace SageTV Beta Test Software 10 03-27-2006 02:41 AM
Hauppauge remote (45 buttons) problem Bagoz Hardware Support 15 01-29-2006 02:42 PM
