Old 02-17-2009, 11:23 AM
Backing up wiz.bin and sage.properties
Is it okay to back up these files while SageTVService is running?
Old 02-17-2009, 01:29 PM
John@TunerUK John@TunerUK is offline
Properties should be fine, and I can't think of any reason why wiz.bin should be any different. They're just text files as far as I'm aware.
Antec Sonata III, Abit AN-M2HD, AMD 4200+, Thermalright SI-128 Cooler, 2GB OCZ DDR2, 2x500Gb + 1x1Tb Samsung Spinpoint SATA II, Hauppauge Nova-T500, Technotrend 3200-S2 with CI, Oasis II CAM. Windows XP Home SP3, Logitech Harmony 525. Logitech DiNovo Edge
Old 02-17-2009, 02:43 PM
wiz.bin is actually SageTV's database that stores the metadata, favorites, history, etc. I believe you need to stop the Sage service before backing that up. I also think there were some scripts developed around that and determining if Sage was recording. Search the forums.
Old 02-17-2009, 03:13 PM
I back up the files while SageTV is still running. If I happen to be doing it manually, I just make sure the file isn't currently getting updated. Otherwise, my backup program just does so as scheduled.
There is a sticky at the top of this forum that lists some people's backup utilities for these files.
Old 02-17-2009, 03:52 PM
Slugger Slugger is offline
How do you determine if "the file [wiz.bin] isn't currently getting updated"?
Twitter: @ddb_db
Capture: 2 x Colossus
STB Controller: 1 x USB-UIRT
Old 02-17-2009, 04:02 PM
Note that I said I'll check it if I'm manually copying it, so it is simply a matter of hitting F5 in Windows Explorer & checking the time stamp and/or file size.
Some of the backup utilities I mentioned might check the file info too.
Wiz.Bin in Sage 6.4 location? Crowdx42 SageTV Software 4 10-05-2008 08:26 AM
Wiz.bin and Sage.Properties Backup Using WinXP Backup Util. mayamaniac SageTV Software 28 05-03-2008 06:34 PM
Just restored wiz.bin, wiz.bak, sage.properties, but no longer have old recordings... GoldenTiger SageTV Software 4 04-09-2006 11:06 AM
When are the Win.bin, Win.bak, Sage.properties, and Sage.properties.autobackup saved? zubblwump SageTV Software 3 01-16-2005 08:54 AM
Wiz.bin and properties file question Crowdx42 SageTV Beta Test Software 3 04-15-2004 11:38 PM
