Old 05-13-2007, 05:17 PM
m4tth3wv m4tth3wv is offline
Stop Sage from mount-ing SCSI/SATA Devices
Everytime Sage starts up it mounts my two SATA drives at /dev/sd*.
Sun 5/13 19:05:03.208 Setup dir for external device mount: /var/media/external/sda1
Sun 5/13 19:05:03.208 Executing process: mount /dev/sda1 /var/media/external/sda1
How can I stop Sage from doing this?
This suggestion has never worked: http://forums.sagetv.com/forums/showthread.php?t=22275
sagetv_0.txt
Old 05-15-2007, 06:07 PM
Spratley Spratley is offline
The same thing happens on my system and I've also tried the suggestion in that link with no success.
Old 05-27-2007, 04:09 PM
<nudge>
Old 05-28-2007, 01:05 PM
Narflex's Avatar
Narflex Narflex is offline
Sage
Set this property to the device names you don't want mounted:
For example:
linux/protected_devices=sda1,sda2
In V6.2 we've fixed it so it doesn't automount SCSI/SATA drives anymore like that. But this property setting will fix the issue for V6.1.
Jeffrey Kardatzke
Google
Founder of SageTV
Old 05-31-2007, 10:43 PM
Long live Sage
Thank you!
Sage has experienced a critical error and must close chadman SageTV Beta Test Software 3 11-11-2006 02:02 PM
Sage UI disappears during playback Keith SageTV Software 17 03-03-2006 03:31 AM
Sage DVD Player vs. Zoom/TT Players Jesse SageTV Software 47 02-17-2006 02:34 PM
Sage deletes all recordings made with HD tuner Jesse SageTV Software 23 02-09-2006 09:35 AM
Sage won't stop recording jkoutrouba SageTV Software 1 02-06-2006 08:47 AM
