Old 02-17-2009, 08:14 AM
cenk cenk is offline
Problem with External DVD Player - Arcsoft Total Media Theater
Hi all,
I am new to the SageTV world. Previously been using Vista Media Center. I have got a small problem I would like some help with please and forgive (correct) me if this is the wrong place to post.
I am using the Media Center executable for Arcsoft as an external DVD player in SageMC (using dvd_player.cmd). It all works fine, launches Arcsoft, plays my BD or HDDVD without problem. The issue is if I press anything other than the directional buttons on my remote it switches back to SageTV (it doesn't seem to sleep, like it should).
Any ideas ?
Thanks.
Old 02-19-2009, 01:37 AM
Wow, thanks for the replies. Anyway, I found the solution, just disable the screen saver. This then sleeps SageTV properly and the remote control only functions with Arcsoft or PowerDVD until the back button is pressed. Just in case someone else needs it.
Replace nVidia PureVideo with Arcsoft TotalMedia Theater? AWS General Discussion 10 08-26-2010 01:48 PM
HD PVR and Total Media Extreme bfb1963 Hardware Support 4 10-02-2008 08:17 PM
Using Arcsoft Total Media Theater with SageTV cybrsage SageTV Customizations 2 08-20-2008 07:35 AM
PowerDVD and Arcsoft Media Theatre Integration honeybrain SageTV Software 2 02-09-2008 10:25 AM
total reinstall results in total diaster - Stacking/Ghosting of menus?! alijiwani SageTV Beta Test Software 4 09-21-2005 10:36 AM
