Old 09-29-2013, 12:36 PM
New Phoenix Core 2.5.6
This build removes TheMovieDB v2 support and adds in TheMovieDB v3 support.
I've been having issues lately with movie metadata not being looked up, and in the logs, all I can see is that themoviedb is returning a 202 success code with no data. I'm guessing they are phasing out v2 api, and I tried to move to the v3 api previously, but I ran into issues, so I rolled it back.
You will need to update the themoviedb libarary to 3.0.1 for this to work.
When I first upgraded, I was getting failed metadata errors, but then I noticed the sagetv plugin system didn't "upgrade" the themoviedb.jar correctly, and I had 2 versions in there... themoviedb-3.0.0.jar and themoviedb-3.0.1.jar. So after updating and restarting sagetv, check the JARs to make sure there are NOT 2 of these in there... if there are... it will not work.
Old 09-29-2013, 05:42 PM
PhilH's Avatar
PhilH PhilH is offline
This killed me completely. I cannot get metadata from tmdb V3 or IMDB. It tells me "unable to get metadata". At least before the update today I could get metedata from IMDB.
I also checked & I have only one .jar installed. themoviedb-3.0.1.jar
I can get data for TV shows so that still works. The problem is only related to Movies.
Any help would be appreciated..
Phil
P.S. Is there anyway to rollback to the previous version so I can at least use IMDB for movies? Thanks
SageTV v7.1.9 Gemstone WHS + 3 HD200's, 1 Client & 1 Placeshifter
WHS - Dual Xeon 2.8ghz - 3gig ECC Ram - 25 Drives - 30 Terabytes
Blu-ray Titles 498
HD-DVD Titles 166
DVD Titles - Too Many To Count..
Old 09-29-2013, 08:39 PM
[JiF]Mike [JiF]Mike is offline
Same thing happening here.
I re-installed SageTV to start from scratch, for some other reasons. Everything is mostly working again except metadata retrieval. I can look up a movie using BMT, but when I click on the correct movie it says "Unable to get Metadata."
There's a lot more sources for metadata than I had previously, but they all give me the same result. The default is listed as "themoviedb.org v3 -- (tmdb3)"
Edit:
BTW I only have one jar listed named "themoviedb-3.0.1.jar"
SageTV: Athlon 64 X2 4200+ | 4 GB | 1 Tuner | DirecTV via HD-PVR | Windows Home Server 2011
Clients: PlaceShifter | (3) STP-HD200
Primary TV: Samsung 61" DLP 1080p
Bedrooms: Toshiba 32" LCD 1080p
Customizations: Pheonix | Web Server
www.jiff.net
Old 09-30-2013, 05:05 AM
Please send the phoenix.log to metadatatools at gmail dot com.
FYI... IMDB simply delegates to Nielm's IMDB lookup, maintained by jrekiwi. Nothing changed in terms of IMDB support.
I did experience the "unable to get metadata" error in BMT, but removing the duplicate jar fixed it, in my particular case.
Either way, I'm sure the logs will show the problem.
Old 09-30-2013, 10:35 AM
PhilH's Avatar
Log sent. Thanks for taking a look at it.
Phil
Blu-ray Titles 498
HD-DVD Titles 166
Old 09-30-2013, 11:09 AM
It is working for me one thing I had to do is uninstall the CMT plugin and re-install it.
Old 10-01-2013, 12:27 AM
Gustovier Gustovier is offline
This seems to have broken me as well. I double checked for the extra .jar file on both the server and the client (I upgraded both). IMDB was working for me before I upgrade phoenix core services and all the other plugins it updated, but now that isn't working either. I also do not have CMT installed. Any ideas?
TV show data and images form thetvdb seems to still be working fine though
Old 10-01-2013, 05:26 AM
IMDB is broken for me as well... although it has nothing to do with this update, since IMDB didn't change. The error that I'm seeing of IMDB is happening inside the "nielm" jar code (which I don't control).
As for TMDB v3... if it's failing, then send me log files. So far one person has sent me a log file, and it doesn't show any errors So maybe with more log files, i'll get more data on what is causing the issue.
I suspect there may be some conflict with another plugin, but I run so few plugins, that everything is working fine on my system.
I did see that when I updated Phoenix on my main server there was was update to the nielm imdb libraries as well, and as such I took them. So, I'm not sure if imdb was broken before this update, or after.. since I never use imdb.
Old 10-01-2013, 07:51 AM
I had to uninstall the Nielm stuff took a while.... because of dependencies then I installed them from scratch and there is no problem using IMDB from the ui to lookup actor and Movie Info and also to save the movie Info. When I updated just the phoenix the first time it broke the Web server and some other Nielm stuff... also broke CMT..
Old 10-01-2013, 09:36 AM
PhilH's Avatar
Hey stuckless
I emailed a new set of log files to you last night. It was all of my log files zipped up. Hopefully it will help..
Phil
Blu-ray Titles 498
HD-DVD Titles 166
Old 10-01-2013, 11:34 AM
Originally Posted by PhilH View Post
Hey stuckless
Phil
Sadly... there are no errors in your log files
Old 10-01-2013, 12:39 PM
PhilH's Avatar
Thanks for looking. Hopefully someone or yourself can get this figured out.
In the meantime I'll just mess with my TV stuff..
Phil
Blu-ray Titles 498
HD-DVD Titles 166
Old 10-01-2013, 01:00 PM
JREkiwi's Avatar
JREkiwi JREkiwi is offline
Just to confirm that the latest nielm_sageimdb.jar (1.8.5) does work with the 2.5.5 phoenix build.
For full disclosure, it is the first release I have done using Eclipse 4.3 (Kepler)
John
Old 10-01-2013, 03:12 PM
John
Thanks John....
Old 10-01-2013, 06:05 PM
I've uploaded a 2.6.7 update to Phoenix.
Old 10-01-2013, 08:40 PM
PhilH's Avatar
stuckless I emailed you the sagetv_0 log file. Hopefully that will help.
Phil
Blu-ray Titles 498
HD-DVD Titles 166
Old 10-01-2013, 10:25 PM
mdnttoker mdnttoker is offline
IMDB works for me (w/limited fanart). But TMDBv3 still doesn't. Will get some logs together. (this is with 2.5.7)
Old 10-02-2013, 04:47 PM
I've updated to 2.5.8.
http://forums.sagetv.com/forums/show...230#post557230
Gemstone and Phoenix Core 2.3.59 - please read jusjoken Gemstone for v7 22 01-01-2014 10:12 AM
Phoenix 2.5.0 Update (api, core, and UI) stuckless Phoenix 38 05-15-2013 03:49 PM
Phoenix Core Services problem sacrament055 Phoenix 15 11-21-2012 10:37 AM
URGENT: Please Update to Phoenix Core 2.3.41 stuckless Batch Metadata Tools 1 09-01-2011 07:24 PM
Help with configuring Phoenix Core Services Chriscic SageTV v7 Customizations 2 01-01-2011 12:33 AM
