Old 10-02-2013, 04:46 PM
New Phoenix Core 2.5.8
The TMDB v3 api relied on a Java 7 api. I've reworked the code so that it no longer depends on Java 7, but come on... Java 6 has been EOLed as of Feb 2013... It's time to move on
So, 2.5.8, just has a small change to TMDB v3 provider and it should work with Java 6 or 7.
Old 10-02-2013, 05:46 PM
mdnttoker mdnttoker is offline
Works perfectly, thanks...guess I should finally take the leap to java 7 on the sage server...
Old 10-02-2013, 07:53 PM
will will is offline
I've been rocking Java 6 for a long time too. Why change what works...
Will
OS: Windows 7
Players: 5 HD300s, 2 HD200s
Old 10-03-2013, 05:44 AM
I understand that on Windows... upgrading Java has been a pain for many people.
Just a word of caution... while I was able to roll out the changes, this time, to make this work in Java 6... There may be other times where I simply won't have the time or will to do so ie, if there's a new feature in Java 7 that makes my life easier as a developer, then I'm going to use it
Old 10-03-2013, 07:52 AM
tvmaster2's Avatar
I've been using Java 7 for a while with my W7 32 bit install...no problems, but I don't use as many plugins as some
Old 10-03-2013, 09:44 AM
PhilH's Avatar
PhilH PhilH is offline
Thanks stuckless. Your work is always appreciated.
Looks like I need to upgrade my Java on my WHS server..
Sorry for the extra work I gave you..
Phil
SageTV v7.1.9 Gemstone WHS + 3 HD200's, 1 Client & 1 Placeshifter
WHS - Dual Xeon 2.8ghz - 3gig ECC Ram - 25 Drives - 30 Terabytes
Blu-ray Titles 498
HD-DVD Titles 166
DVD Titles - Too Many To Count..
Old 10-03-2013, 09:54 AM
routerunner's Avatar
Thanks Sean, however if you plan to make any future update that will require upgrading to Java 7, then I kindly ask you to specify the minimum required JVM version in the plugin manifest, this way the user will have, at least, the option to decide whether it is worthwhile make the JVM upgrade without creating any incompatibility issues with the existing setup
Eddy
Old 10-03-2013, 12:55 PM
Eddy
That's a great idea... I'll add that into the next release. This is important, especially since I wasn't aware that I had used a Java 7 api, I just don't have anything else installed except for Java 7. Next release will include Java 7 manifest entry. (I forgot about that option in the plugin definition)
Old 10-03-2013, 03:54 PM
sflamm sflamm is offline
FYI - Java 7 works fine with SageTV on all platforms... I am currently running Java 7 update 40 on all of my clients (Win XP, Win 7, Win 8) and my server (Win 2012). No problems whatsoever.
In fact - it is a significant performance improvement over Java 6.... a google search will quickly show the qualitative/measurable details of the performance difference.
Old 10-03-2013, 03:56 PM
Is this latest update safe? Does it have all the old functionality working or is there something we should make note of?
Old 10-04-2013, 06:32 AM
It's as safe as any release... the 2.5.6+ releases was done to address an issue in the movie metadata lookups... and as such it uses a new library for accessing tmdb.
Old 10-04-2013, 08:03 AM
PhilH's Avatar
It works fine here. All of my troubles went away with this release..
Blu-ray Titles 498
HD-DVD Titles 166
Old 10-04-2013, 08:43 AM
Better than safe, fixed all IMDB and TMDB issues for me...
New Phoenix Core 2.5.6 stuckless Phoenix 17 10-02-2013 04:47 PM
New Phoenix Core 2.5.7 stuckless Phoenix 0 10-01-2013 06:04 PM
Phoenix 2.5.0 Update (api, core, and UI) stuckless Phoenix 38 05-15-2013 03:49 PM
URGENT: Please Update to Phoenix Core 2.3.41 stuckless Batch Metadata Tools 1 09-01-2011 07:24 PM
URGENT: Please Update to Phoenix Core 2.3.41 stuckless Phoenix 0 09-01-2011 07:14 PM
