Old 07-01-2014, 02:44 PM
nlancaster nlancaster is offline
3D Acceration will not stay on
I just build a new low power low noise SageTV Client.
AMD A4-5300 APU contains and ATI Radeon HD 7480D graphics built in.
8GB Ram
60gb SDD
The 3d acceleration will not stay on in sagetv client.
Turn on 3d acceleration, and as soon as you move away from the setting it goes back to disabled.
Updated drivers, made sure sagetv client was up to date, same issue.
SageTV Server: AMD Athlon X2 4400+ 65W, 2GB PC6400 Corsair Ram, Liteon 20x DVD-RW, 2 x HVR-2250 - 1 x HVR-1800 - 2 x HD-PVR, 1 x 1TB - 1 x 2TB - 2 x 500GB - 3 x 750GB, 3 x SageTV Clients
Old 07-02-2014, 07:47 PM
OneOfMany OneOfMany is offline
I am not sure of the issue, but have you downloaded the catalyst suite for the Radeon card? I know if you use the default Windows drivers you will not get all of the features of the card in gaming.
Grant
Old 07-05-2014, 09:17 AM
Yep, downloaded all the latest drivers.
Old 09-17-2014, 10:04 AM
TobyG TobyG is offline
I had this issue with my AMD APU. I fixed it by allocating more video memory in the BIOS (I believe at least 1GB did the trick, but if that doesn't work try allocating more).
Stay or Bail ? daz19 SageTV Software 312 08-17-2011 05:04 AM
tweak to get cover art to stay loaded veger69 SageMC Custom Interface 10 01-09-2010 03:25 PM
HTPC Won't Stay Off Polypro Hardware Support 16 12-02-2008 09:48 AM
I have to stay at version 3.x - can't upgrade to 5.x Steve2112 SageTV Software 8 08-12-2006 02:10 AM
client won't stay connected havock2 SageTV Software 5 08-20-2005 04:05 AM
