Old 09-12-2005, 01:58 AM
doron_amedey doron_amedey is offline
2 Set-top-boxes using 2 150 with ir-blaster.
hello friends,
due to the work that has to be done with the 500, i loaned another 150 card.
now i have 2 150 cards on my htpc running sage.
i noticed that the Ir-blaster config, only works with one of them (my first 150).
how can i make my second 150 Ir-blaster to work as well (separately of course).
please advise.
Old 09-12-2005, 02:08 AM
You'll have to get another IR blaster if you want IR control of 2 STBs, since only one of the Hauppauge blasters can be used at a time. (Unless the 150s are in 2 different PCs.) The USB-UIRT is fairly popular for controling multiple boxes.
Old 09-12-2005, 02:13 AM
thank you andy,
I'm sorrry i'm not following (newbie..).
if i have (on same pc) 2 hauppauge 150 installed, each with its own ir-blaster, in sage i "told" him that the second is using ir blaster, but it wount use it.
i'm not sure what you ment by to get another ir-blaster.. i for each one of them its original (of course each is connected to different set-top-box).
Old 09-12-2005, 02:27 AM
ke6guj ke6guj is offline
what Opus means that you can only use one Hauppauge IR-blaster, even though you physically have 2. The hauppauge software that controlls the ir-blaster is not sophisticated enough to run multiple ir-blasters, it even has a problem finding a single blaster in a computer with retail-150's and MCE-150's.
For a second ir-blaster, you would need to use a different brand blaster, one that uses a com port or USB, like the USB-UIRT that Opus recommended.
Old 09-13-2005, 02:00 AM
thank you, now i understand,
i bought usb-uirt, but i can't find a place to buy a "stereo" jack with 2 ir's on it.
if anyone has any can i find and order one, i'll appreciate it.
Old 09-13-2005, 11:35 AM
folly12345 folly12345 is offline
If you have a Radio Shack nearby, it is fairly easy to make one. The directions and parts are listed in this thread http://forums.freytechnologies.com/f...light=usb+uirt
Old 09-14-2005, 06:54 AM
thank you very much for the help.
i now believe i have all the answes.
many thanks.
