Old 10-10-2005, 01:46 PM
01blacksnake 01blacksnake is offline
Exclamation Need help with my Hauppauge pvr-500MCE and recording!
Hey everyone... thanks in advance.
I recently bought a hauppauge pvr-500MCE for my windows XP system (I know it was optimized for use on MC editions of XP, but was told I could use the card).
I've been trying to connect my VCR to the card to copy over some old VHS tapes onto my PC.
I've had a hell of a time finding an application do this with! I've tried the SageTV recorder, but I guess the recorder doesn't support the pvr-500MCE.
I'm really hoping that someone knows of a product that will allow me to record these VHS tapes onto my PC.... thanks!
-Ray
Old 10-10-2005, 02:16 PM
phantomfsoc phantomfsoc is offline
I use SageTV to record my old home videos. I setup the capture cards input and then hook up my vcr. I then make a timed recording of whatever length the VHS is and thats it. They always come out fine
"JUST WHEN YOU THINK YOU GOT IT...... YOU GET A NEW TOY TO START OVER WITH"
AMD xp 2500, 512m DDR, MSI 6600Gt 128, SageTV Client 6.12, Toshiba 34hf83 HDTV
Old 10-10-2005, 02:30 PM
ke6guj ke6guj is offline
SageTv should work just fine, just not SageRecorder
Old 10-10-2005, 02:40 PM
Hm... having issues with that, too.
How about a strict recorder that would work? any ideas?
Old 10-10-2005, 02:49 PM
I am trying to "add new source" in SageTv and I keep getting errors.
I select the hauppauge tuner #1, then select to "captuer composite" since my VCR is hooked with red/yellow/white audio/video cables to my hauppauge card.
Then I select "con't configure tuning," and "do not use programming guide."
When I try to view the vcr output, I just see a blank screen.
I also get the "There was a problem accessing the filesystem for playback" save.Playback.Exception:Error(-3,0x80040154).
