Old 12-13-2008, 07:47 PM
personalt's Avatar
personalt personalt is offline
IR Blaster - Can I change IR commands so two boxes dont interfere
I think I can do this, but I want to be sure before spending a few dollars on a IR blaster and stick all my sage boxes in one closet.
Can I remap the sage commands on one of the boxes so that if I blast the signal for two or more sage boxes in the same closet they dont interfere?
It appears from the command menu i can remap commands to new IR commands but i wanted to make sure that is what the menu is saying since I dont have the IR blaster yet.
Old 12-13-2008, 07:59 PM
MrD MrD is offline
what are you trying to control? most boxes have alternate codes for this reason. also the usb uirt has multiple channels so that one set of commands can be discrete to each box
[size=1]-MrD
Linux Server 7.1.9 (1)HD300 (1) HD200 (1) HD100 (2) PC Clients
Intel Xeon L? 32Gb
CetonTV cable card /FIOS
Old 12-13-2008, 08:32 PM
personalt's Avatar
I want to stick 4 sage boxes in a closet. I was thinking of getting a xantech or niles ir hub.
something like this
http://www.crutchfield.com/p_190MSU4...rch=ir&tp=3375
Currently I run a IRA-2 into CQC which then controls the extenders via tcp/ip.
However I find there to be a litttle extra delay that way that is getting annoying
I was trying to get away from the computer. are you talking about using usb irt as a reciever or sender of ir data? or both?
Old 12-13-2008, 09:08 PM
CollinR CollinR is offline
Yes you can just try it, it's in detailed setup.
Old 12-13-2008, 10:29 PM
If you mean having 4 extenders in the same place: you can probably reprogram all IR codes except Power, so the same IR codes will turn them all on or off, or some combination that depends on the power state of each one. There are discrete power on & off codes, but again: the codes are the same for each one & can't be customized.
Old 12-13-2008, 10:41 PM
personalt's Avatar
in the hd200 menu it looks like you can customize the power on/off buttons
could that be in the hd200?
MCE blaster with HD-PVR and other tuner? SageGk Hardware Support 1 12-08-2008 05:58 PM
MCE IR Blaster Question Striker:WG Hardware Support 0 11-30-2008 11:43 PM
IR Blaster in HD-PVR stops responding showson1 Hardware Support 8 10-17-2008 09:49 AM
Harmony 520 Remote With Hauppauge Commands Taddeusz Hardware Support 5 04-27-2007 06:04 AM
blaster NO work globulus Hardware Support 2 03-19-2007 08:13 AM
