Old 05-03-2009, 10:00 PM
-=Jeff=- -=Jeff=- is offline
Issue with HDHR (HDHR works fine)
I am having a Sage issue with one tuner on one of my HDHRs..
I have a total of 2 HDHRs and the first one I bought a while back works fine. the newer one however one one of the tuners is working properly within Sage. the other shows no signal.
if I try it in the HDHomerun Setup program I can watch shows on any of the 4 tuners, whichever I select works.
I removed the tuner from Sage and Tried to reinstall it but it will not work. is there a File or something to delete to try and add the tuner back in and see if it works?
Like I said all 4 tuners work int he HDHomerun Setup program, just one acts odd in Sage
Server: Win 10 Pro 500Gb OS, 1x 1.5TB & 2x 2TB HDs for recordings
Tuners: 3 HDHRs OTA
Client 1: HD100 on 65" Samsung 4K LCD\LED
Client 2: HD100 on 50" Panasonic Plasma (16x9)
Client 3: HD100 on 32" Toshiba Tube (4x3)
Old 05-03-2009, 10:06 PM
think I figured it out..
renamed the scn file to .old and am trying to rescan in sage
Tuners: 3 HDHRs OTA
Why default UI works fine but SageMC occasionally hangs? t4uecker SageMC Custom Interface 0 03-25-2009 11:36 AM
Tuner issue after HDHR install jcato Hardware Support 3 10-17-2007 10:29 AM
MY wMVP works just fine schmots SageTV Media Extender 9 09-17-2007 06:27 PM
Wintv works fine, Sage just gives static DanA SageTV Software 9 05-26-2006 03:58 PM
PVR-150 works fine with wintv won't with sage gunnyhud SageTV Software 7 01-22-2006 04:11 PM
