Old 10-18-2010, 04:36 PM
soulprops77's Avatar
soulprops77 soulprops77 is offline
Another failing API - 1.204
Hey folks,
Every time I try to install SMM the API fails on my client and extender. I just tried a totally clean client install and the same thing happened.
I'm attaching my log below. If anyone has any advice that isn't in the other threads, I'm all ears.
Chris
EDIT: I'm using the latest beta, 7.0.20.243
Old 10-18-2010, 04:44 PM
PLUCKYHD PLUCKYHD is offline
What version of mymovies collection manager?
Old 10-18-2010, 04:54 PM
3.17 on both the client and server.
Old 10-18-2010, 05:02 PM
please read the wiki and the documentation.
"Since you can't grab 3.17pr3 anymore you will need that to install 3.18pr1"
Windows 7 64bit Home Premium
1tb 3 disk Recording Pool
all in a beautiful Antec 1200
HD100/HD300 extenders
Old 10-18-2010, 06:00 PM
Thanks JP. That seemed to have worked. . . To a point.
Now all that shows in SMM is two items. Gladiator and something called "Season 1."
"Season 1" seems to be "Lost: Season 1" which is my Netflix queue. For some reason MyMovies keeps picking this up (obviously through the PlayOn importer plugin" but no other TV shows in the queue. . .
Also, I did poke around in the wiki for this and I'm not sure if it's intentional, but the rebuild datafile option is gone from SMM. . .
Old 10-18-2010, 06:04 PM
Sounds like you might have an issue another user had.
Wiki hasn't been updated to that yet but the rebuild of the datafile is located under the smm-API configuration settings now. Try that and if that doesn't work see the wiki and get me some logs to see if your problem is similair to another users.
Old 10-18-2010, 07:08 PM
I rebuilt the database and I'm still only getting those two items.
Should I go ahead and open up a bug on the wiki?
And also. . . Anyone know why that "Season 1" item keeps showing up in MyMovies and SMM?
Chris
Old 10-18-2010, 07:11 PM
Chris
Chris just enable trace logging and send me those logs per the wiki.
As for the season 1 what directory of playon did you add to the collection manager? At what level.
Old 10-18-2010, 07:16 PM
I added the lowest level to Collection Manager. . . I was under the impression that it had to be the same as what I entered into the PlayOn importer plugin config.
I'll change it to just the movies folder now and see if that works.
Just to be clear, I will then have the Playon plugin set to "\\HTPC\Media3\Netflix"
which contains a "TV" and "Movie" folder and Collection Manager set to monitor "\\HTPC\Media3\Netflix\Movies"
Is that correct?
Old 10-18-2010, 07:28 PM
Correct. You don't want the tv in the collection manager.
Old 10-18-2010, 07:46 PM
Thanks.
Got that part out of the way.
SMM API V1.200 Keeps Failing foleyma Sage My Movies 11 10-17-2010 10:56 PM
SMM API install keeps failing craigap Sage My Movies 25 10-06-2010 08:42 AM
Api Failing with 1.190 Beta Hyrules Sage My Movies 5 09-23-2010 07:41 PM
Sage API - sagetvmsg.txt - Can API tell if HDPVR Crashed? personalt SageTV Customizations 4 08-25-2010 04:56 PM
