Old 02-12-2011, 07:29 PM
datoney datoney is offline
How do I get rid of the filename under cover art!
http://i563.photobucket.com/albums/s...lyfilename.jpg
Hi all!
I have loaded all of my movies into sage 7, used BMT to get all of my meta data and wonderful cover art. However I have some movies off the wall movies that are not in IMDB etc and meta data and cover art is not getting pulled down. When this happens I am left with an ugly bar under the cover art containing the filename of the movie, is there a way that I can get rid of that???
Datoney
Last edited by Opus4; 02-14-2011 at 01:01 PM. Reason: image too wide to post inline; changed to link
Old 02-13-2011, 04:45 PM
Red face Wow!
Wow! I guess it is tougher to get rid of these filenames than I expected! Does no one have any idea?
Thx
Datoney
Old 02-14-2011, 08:57 AM
Have you gone into the BMT webUI and added that information to those particular movies and saved it? Once you manually provide the movie titels and anything else you want to add to it I believe the titles will go away like thwe other ones in your screenshot.
Old 02-14-2011, 09:31 AM
BMT GUI
I have messed around in the GUI a little, but haven't filled out all of the fields. I will try that tonight when I get home and see what happens. I will post the results, thanks for the idea Gerry.
Datoney
Old 02-15-2011, 10:24 PM
Tried filling out BMT WebUI
I filled out every open field in the BMT WebUI and still the filename remains, any other ideas? Thanks for the input it was worth a try. Is there anywhere else in BMT (perhaps config) where I may be able to disable them?
Datoney
Old 02-16-2011, 11:12 AM
AWS's Avatar
AWS AWS is offline
not much help but...
I agree with you, too. What I have found out is that, at least on my setup, the imported videos (AVI, MKV, etc) all have filenames but the ripped DVDs and BluRays *mostly* do not. What I haven't figured out is why some ripped media has the filename while others do not. I would really like to have all the system-generated titles and folder graphics removed, too.
...subscribing to thread.
AWS
386DX, 40MB HDD, 5-1/4" & 3-1/2" Floppies, 14.4K baud modem, DOS 6.2 and Windows 3.1 on a Samsung 55" LCD
Old 02-16-2011, 11:29 AM
PLUCKYHD PLUCKYHD is offline
AWS
Diamond
Without that I think the fanart plugin has a option to remove the titles on a wall type view as well.
maybe the customfolders plugin but not sure on that one.
Old 02-16-2011, 09:16 PM
Plugin
Thanks PluckyHD and AWS, AWS let me know if you have any luck with the plugin, I will give it a try when I have a min!
Old 02-16-2011, 10:35 PM
Diamond
I installed Diamond and I when I goto my videos and then click on folders I still see the filename, do I need to do something in diamond to turn off the filenames?? Thanks
datoney
Old 02-16-2011, 10:51 PM
jorton jorton is offline
datoney
I think Plucky was suggesting you use the Daimond Wall or Flow views they are both poster views. We don't currently modify the default Title view or Folder view with the Diamond mod.
Old 02-17-2011, 01:53 AM
AWS's Avatar
AWS AWS is offline
I did have MBDiamond v.1.63 installed. But it wasn't the active theme... just intstalled. So I uninstalled it and rebooted. I do still have the titles.
BTW, the same sort of title is also present in "Photos".
Still looking around for a solution.
AWS
Old 02-17-2011, 05:37 AM
AWS
Mbdiamond is a theme you want diamond the ui mod.
Old 02-17-2011, 09:27 PM
AWS's Avatar
AWS AWS is offline
Wink I must not see something
Plucky: I installed Diamond and I'm still seeing the folder names and folder graphic overlaying the videos. I went into Diamond settings under both TV recordings and Videos and I didn't see a setting that would toggle said titles on/off. Am I missing something?
Hey, this looks a whole lot like my XBMC PC... :-). I like it!
Old 02-17-2011, 09:30 PM
Yes you need to use the diamond flow or diamond wall views is what I was getting at
Old 02-17-2011, 11:33 PM
Diamond flow
yep I understand the whole diamond flow thing but I have my movies sorted by folders, my daughters movies, mom and dads movies, home movies etc. It is really easy to find things that way, diamond flow & Diamond wall, look pretty cool but lump all of our movies in the same place. I really like the separation of our movies. Thanks for all of your inputs, I am still looking for a solution , Any other ideas?
thanks
Datoney
Old 02-17-2011, 11:59 PM
thanks
Datoney
In the upcoming version of Diamond you will be able create custom movie views based on the Diamond Wall/Flow/List views and then use folder filtering (include/exclude) to show only the folders in each custom view you want like "Mom and Dad's Movies", "Kids Movies", "Home Movies" etc...
http://forums.sagetv.com/forums/show...&postcount=788
http://forums.sagetv.com/forums/show...&postcount=726
Jeremy
Old 02-18-2011, 12:10 AM
Jeremy
That will be sweet, I really do like the look of Diamond, but gotta have those folders, it's nice to keep things separated and organized! Thanks for the reply
Old 02-18-2011, 05:23 AM
Yeah the be folder exclusions will basically give you those folders at the main menu level
Best Source for Cover Art? KeithAbbott SageTV Software 3 11-17-2010 08:21 PM
MKVs and Cover Art will SageTV Beta Test Software 2 11-05-2010 07:18 PM
Disappearing CD Cover Art??? scm SageTV Media Extender 3 12-19-2009 10:38 AM
DVD Cover Art len12121 SageTV HD Theater - Media Player 13 12-17-2008 07:40 PM
DVD Cover Art... robhix SageTV Software 9 08-18-2008 10:52 AM
