Old 11-26-2011, 12:09 PM
fidget's Avatar
fidget fidget is offline
HD-300s Failing
In the last three weeks, I have had two of my HD-300s develop network problems. The first one lost the ability to see the network and the second one lost the ability to play videos. I was never able to get the first 300 to be able to recover and had to replace it with one of my backups (a unit reserved for a different TV in the house).
the second unit was able to navigate the page tree, but when I tried to play a video, the log on the server appeared to be getting network errors (as if the 300 wasn't processing the data). Fortunately, a hard reset on the unit solved the problem, but I am afraid that it isn't long for this world. Unfortunately, I don't have a backup for this unit.
Are the HD-300s prone to network failures? If so, is there a known fix li,e there was for the HD-100 power supplies?
DVD Storage: 24 TB
Clients: 3
SageTV Extenders:5
Another failing API - 1.204 soulprops77 Sage My Movies 10 10-18-2010 07:46 PM
SMM API V1.200 Keeps Failing foleyma Sage My Movies 11 10-17-2010 10:56 PM
SMM API install keeps failing craigap Sage My Movies 25 10-06-2010 08:42 AM
Api Failing with 1.190 Beta Hyrules Sage My Movies 5 09-23-2010 07:41 PM
Activation failing Dekard SageTV Linux 10 05-23-2006 06:54 AM
