Intel NUC vs HD300 ?
So Intel NUC's have got to the point where they are as small as power efficient as our HD300 extenders. Has anyone done a video/audio quality comparison between a PC like a NUC running the Windows Sage Client vs just using an HD300? Those NUC's also have IR sensors, which makes the prospect more interesting.
Due to the lack of HD300's, I know many users have been forced to come up with a Sage Client solution on a PC, but I didn't know if that has passed the threshold of being preferred. I love my Sigma based HD300's, but if the upscaling, video quality and deinterlacing of a full blown NUC PC happens to be better, that is something to consider....especially if I can get that PC to run other things like PlexHT.
Server: ASUS Q87M-E, Intel i5-4590S, 8GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 9TB disk, 2x HDHomeRun, HD-PVR 1212, Win8.1-64bit, Sage 9 Client 1: HD300 on Panasonic Plasma TC-P50ST60 Client 2: HD300 on Vizio 40" Others: Sage Client & Placeshifter |
Andy, I believe did a review over at missing remote once on the NUC I5. I would go there and look for his review on it.
I've never owned an HD300 and have used PC clients exclusively. I went from a fairly large HTPC in an Antec Fusion case to an Intel NUC and absolutely love it. The only downside is that they're a bit expensive after adding the memory, storage, and OS. I did find I needed to use LAV codecs on the NUC rather than the MS ones in Windows 7. In our house, we use the TV for web browsing nearly as much as for watching media. I can't tell you how many times we've been missing an episode for whatever reason and just fired up the browser and watched it on the network website, Hulu, or Amazon. Since it's a common question, yes, it does HD audio and even 3D.
Server: XP, SuperMicro X9SAE-V, i7 3770T, Thermalright Archon SB-E, 32GB Corsair DDR3, 2 x IBM M1015, Corsair HX1000W PSU, CoolerMaster CM Storm Stryker case Storage: 2 x Addonics 5-in-3 3.5" bays, 1 x Addonics 4-in-1 2.5" bay, 24TB Client: Windows 7 64-bit, Foxconn G9657MA-8EKRS2H, Core2Duo E6600, Zalman CNPS7500, 2GB Corsair, 320GB, HIS ATI 4650, Antec Fusion Tuners: 2 x HD-PVR (HTTP tuning), 2 x HDHR, USB-UIRT Software: SageTV 7 |
OK, that's cool. I wonder if I should fork out the money to buy one and see how it compares.
It would be nice to have a single box act as a Sage client, PlexHT client and Squeezebox client, assuming I can find a nice USB S/PDIF interface. I'm sure there is a way to run all clients and use a remote button to bring the appropriate one to the forefront in Windows. It's quite upsetting the new (lower powered?) Broadwell NUC's require a fan.
I've got a Chromebox (basically a Celeron NUC) running OpenELEC, and my HD300. I'd say for 1080p content, they are very close. The Intel GPU seems to drop/repeat frames occasionally (this is with 1080p24 output) as seems typical with PC based solutions.
I really haven't played with it much, but the deinterlacing seems pretty abysmal in OpenELEC/XBMC, that's one area where the HD300 shines, not in it's deinterlacing capabilities, but in it's ability to bypass them and output content at native resolution (ie 480i for 480i content) allowing external processors to handle it. Chromeboxes are pretty cool, $150 and ready to go right out of the box. You have do have to "root" them (to use the "in" term these days), but I'm pretty sure you can run Windows on them. Apprarently there are some DRM issue, I think HDCP compatibility is not recognized, not available. Quote:
Going from Rasplex to PHT on a Windows box is probably a step up. My worry is Windows Sage Client compared to an HD300 is a step down. 'Not a fan of ever using XBMC natively. Not good at any one thing and a compromise on everything.
If you're not using native output switching on your HD300, I probably wouldn't worry about it, especially under Windows which, IIRC, has better hardware deinterlacing support than OpenELEC/XBMC/Linux.
As for XBMC, I don't know, I've grown kind of fond of it. It's really nice (with the Ace skin) for browsing/watching my ripped content. I think everything I have loaded into it is either Blu-ray sourced or processed with AVISynth to 1080p (some special purpose processing on animated DVDs). And it's really nice that it reads MKV forced/default subtitle flags, instead of always having to toggle them on manually in Sage. But if there's hope of getting MadVR going in Sage, and renewed UI development, I might have to look into a new PC based SageClient setup for my HT, and moving back to using SageTV for everything. |
The current HD300 uses HDMI to my TV, so when I want the option for surround sound to my AV receiver, I use S/PDIF (mute TV). I don't want the HD300 HDMI to my receiver because that means the kids can't easily use it, and surround isn't always needed.
I'd like to reconnect my Blu-ray player full time because it does my Netflix & Amazon. Yes, I hardly watch Blu-ray discs anymore. The NUC would replace my HD300 and Rasperry Plex device, so I gain back the HDMI port for Blu-ray. My only concern is making the NUC seamless for family. I'll need to do some remote IR wizardry. By default, having it boot to the Sage Client interface would be preferred. Edit: The S/PDIF would also be useful for a squeezebox client. I have that now on a Cubox with S/PDIF, but no HDMI is needed. it's currently headless
The PC client is in many ways preferred to the HD300. For one, the UI is often much smoother on the client. It also allows as lot of customization. I use ffdshow and have tweaked the audio settings, channel levels, etc for each room.
Buy Fuzzy a beer! (Fuzzy likes beer) unRAID Server: i7-6700, 32GB RAM, Dual 128GB SSD cache and 13TB pool, with SageTVv9, openDCT, Logitech Media Server and Plex Media Server each in Dockers. Sources: HRHR Prime with Charter CableCard. HDHR-US for OTA. Primary Client: HD-300 through XBoxOne in Living Room, Samsung HLT-6189S Other Clients: Mi Box in Master Bedroom, HD-200 in kids room Last edited by Fuzzy; 03-20-2015 at 09:03 PM. |
I love my Harmony 890, but the buttons aren't built to last. The new Harmony Home Control is very nice, too, especially for non-technical people. In fact, I just set that up for my in-laws to control their TV, STB, Soundbar, and Blu-ray player. They LOVE it. You no longer need IR blasters attached to your devices, which is great. I want something a little more advanced to replace my 890, but the Harmony Ultimate Home has a terrible button layout with the play/pause/ff/rew/stop/rec at the very top of the remote. At this point, I'll wait and see what Logitech comes out with next.
OK thanks. I'm a die-hard MX700 remote user, but I'm sure I can make it work. I didn't even think about remote commands randomly changing things in the background on other running apps. I'm glad Eventghost handles that.
+1 for using Chromebox
The pad around the ok button can be used for fwd/rew and the ok can be used for play/stop by default. Connecting it to the pc harmony app lets reprogram hard/touchscreen keys to do everything the harmony one can do...just not as easy to find as the app is not as intuitive. Later this summer they will be releasing a companion zigbee hub for so can directly control light scenes for an example.
http://forums.sagetv.com/forums/showthread.php?t=56137
Server: ASUS Q87M-E, Intel i5-4590S, 8GB RAM, DR-400-6 RM case, 2x Addonics Disk Array 3SA, 9TB disk, 2x HDHomeRun, HD-PVR 1212, Win8.1-64bit, Sage 9 Client 1: HD300 on Panasonic Plasma TC-P50ST60 Client 2: HD300 on Vizio 40" Others: Sage Client & Placeshifter Last edited by valnar; 03-21-2015 at 07:04 AM. |
Check MSI Cubi that come out look nice just wonder what it going to cost the choices include option are Core i5-5200U, Core i3-5005U, Pentium 3805U, and Celeron 3205U.
I honestly appreciate the alternative control information you provided, so THANK YOU, but it just doesn't sound very intuitive. Given the separate play/pause/etc buttons at the top of the remote, it's almost like the designers of the hardware did their job and then the software engineers took one look at the button layout and went, "Oh crap" and had to find a workaround for a poor design. It's truly a shame that Logitech is the only company making remotes like this (don't even get me started on URC).
Damn I just find out that hauppauge going have Tuner add-on that can be mount directly on top of new NUC by remover black NUC top cover
I wonder how the cheap Baytrail atom boxes will run the Sage Client..?
I've got a Baytrail tablet - and overall performance is just fine - except for running out of memory if I run too many programmes or too many browser tabs at once - for every day use or Plex playback it is flawless. Not really tried it with Sage - but I imagine they will play back anything I typically throw at it. They are crazy good value. A touch over $100 including memory and storage, so probably getting onto a third of the price of a NUC once you add storage and memory. I could/should probably do some testing on my tablet, but frankly don't have the time at the moment, but just talked myself into one as I had the urge to buy some new tech (don't you hate that feeling)... This is on the way (There must be something I can find a use for it with - even if not SageTV): http://www.geekbuying.com/item/PIPO-...ck-340056.html |
Intel getting in the mix? | pjpjpjpj | General Discussion | 18 | 01-22-2014 09:08 PM |
Mac 6.3.5 on Intel | flavius | SageTV Beta Test Software | 9 | 01-17-2008 12:24 AM |
Intel GMA 950 | wrems | Hardware Support | 3 | 05-22-2007 06:57 PM |
Intel Mac Mini | obbiie | SageTV Linux | 0 | 10-03-2006 10:06 AM |
Best Intel CPU for HD Client? | aglennon | Hardware Support | 19 | 09-13-2006 09:57 PM |
