Parental usage log plugin?
Folks,
Are there any plugins for logging the viewing history of either Sage Client or PlaceShifter? That is, can you monitor / audit the channel, time, and duration of what a kid has tuned to? Even better would be the program name too. I would have thought someone went down this road before, but I'm not finding a plugin for it. Sam |
I haven't seen such a plug-in. You can in the meantime enable debug logging, which should generate a .txt file with everything including chanels and files accessed.
The problem with this is that it may slow things down a bit on slower systems but on faster systems it's not noticeable. Now If only a kind soul could write a filter to process the .txt file and extract only the required info...... ![]()
Windows 10 64bit - Server: C2D, 6Gb RAM, 1xSamsung 840 Pro 128Gb, Seagate Archive HD 8TB - 2 x WD Green 1TB HDs for Recordings, PVR-USB2,Cinergy 2400i DVB-T, 2xTT DVB-S2 tuners, FireDTV S2 3 x HD300s |
