Waking Client
I have just completed mi Biostar Mini PC to run Sage Client and moved Sage to my server. With SageTV I had my remote set so she just pushed power on ad Sage would start if it was closed or wake up if a sleep. With the client a new instance of the clien starts if it is a sleep.
Searched the forum and found an old post on using the -awake modifier with SageTV but this does not seem to work with the client. Anyone any idea how I can get the functionality back with the client. |
From this reply...
http://forums.freytechnologies.com/f...ighlight=awake From george_s worked for me... After poking around the forums here I found an alternative solution to the inability to wake reliably. Several posts hinted that the problem was in hauppauge irremote focus. Here's irremote.ini entries that seem to reliably sleep and wake with via remote: In the [default] section: GRNPOWER={run(C:\Progra~1\FreyTe~1\SageTV\SageTV.exe -awake)}{mode(SageTV)} In the [SageTV] section: GRNPOWER=z{mode(default)} I believe the trick is to force the mode of the irremote software after waking or sleeping sagetv. Another post had the following link that documents the irremote software commands: http://dschnabel.virtualave.net/irdocen.htm Don't forget to recycle your remote in... Finally save it and go to the huappuage listing in the start menu and run restart IR. This should wake SageTV. |
