Old 06-09-2008, 06:15 AM
taylormadearmy taylormadearmy is offline
Good screen or laptop for outdoor use
Does anyone know of a screen or laptop that has a screen that works well in direct sunlight?
I fancy making the most of the 2 weeks of England's summer!
T
Old 06-09-2008, 06:36 AM
You're looking for a laptop with this type of screen:
2. Transflective LCDs
Transflective construction starts with a transmissive LCD and adds a partially reflective mirror layer between the LCD and the backlight. Depending on the LCD manufacturer, the mirror layer can be either a half-silvered mirror or a full mirror with tiny holes punched in it. When a transflective LCD is used indoors, it is illuminated by the backlight just like a transmissive LCD, except that the mirror layer blocks some of the light. When a transflective LCD is used outdoors, ambient light reflects off the mirror layer and illuminates the LCD. Note that outdoors, light has to go through the LCD twice, once on the way in and once on the way out. This tends to makes the outdoor performance of a transflective LCD not as good as the indoor performance, where the light only has to go through the LCD once.
The balance between outdoor and indoor performance can be adjusted during manufacture of the LCD by varying the reflectivity of the mirror layer. For example, the mirror layer might be set to reflect 60% and transmit 40% of the light.
This means that if the normal indoor brightness of the LCD is 130 nits, only 52 nits (40% of 130) is transmitted from the backlight through the mirror layer and the LCD. Outdoors, 60% of the light hitting the mirror layer is reflected, but since the light has to go through the LCD twice, the user actually sees less. A transflective LCD is therefore by definition a compromise. It can never be as bright as a transmissive LCD indoors, and it can never be as bright as a reflective LCD outdoors.
I know the Panasonic Toughbooks have this on some of their models but Toughbooks aren't cheap. Here's one example:
Toughbook 74
Old 06-09-2008, 07:36 AM
matt91's Avatar
matt91 matt91 is offline
The "$100 laptop", the XO, was partially designed to work well in direct sunlight. I think some are available on ebay.
Old 06-09-2008, 07:45 AM
Thanks - is it grunty enough for Placeshifter - has anyone here tried it?
T
Old 06-09-2008, 07:47 AM
doc doc is offline
T
I'm afraid I can't help out on your question, but I think you'll find you've missed the English summer, it was in 1976!
Old 06-09-2008, 07:57 AM
matt91's Avatar
T
Good question. I haven't tried it, but have been meaning to. There is another guy who has an XO here, and he had said that he wanted to try it too.
There is a new OS release that I've been meaning to install, so maybe I'll do that and try to install the linux placeshifter as well and see what happens.
Matt
Sage screen not repainting db533 SageTV Software 14 06-04-2008 01:01 PM
Sage Shows Black Screen (no UI)? rwc SageTV Software 3 03-19-2008 05:54 AM
STX-HD100 Screen Saver Not Working polen SageTV Media Extender 18 03-18-2008 04:10 PM
Force Full Screen in Sage mike1961 SageTV Software 10 06-22-2006 11:52 AM
SageClient Laptop keeps changing time kmac SageTV Software 0 05-06-2006 08:00 AM
