hd 200 announcements and bug fix question
the last 2 announcements of new beta releases have been in a different forum?
permanent change? Also, todays notice Changes for beta version 20090701 0 include the following: Core changes: Try to improve network performance when accessing servers with broken tcp window scaling Updated startup screen What does this refer to Try to improve network performance when accessing servers with broken tcp window scaling and is it something we should be able to or try to fix on servers if we have it and how do we figure out if we have it? Thanks
Server: PhenomII X4 810, 16GB, 4850, C: 256GB Samsung SSD, D: HGST 3TB, E: HGST 4TB, H: 3T Seagate, 1.5 TB on NAS via UNC, Win 10 x64, Sage 9 Cable provider is Comcast, Schedules Direct Tuners: 4 ATSC - 2 seperate HD Homeruns all via Channel Master CM2016 on roof, 6 cable via 2 hdhomerun primes (opendct), 1 HD-PVR (in tuner priority order) Clients: Wired: HD300, HD200, HD200 running Squeeze Slave, Placeshifters, HD200 (via wireless N bridge) |
_Demo_ |
interesting.
I have problems with hi bit rate files with some firmwares, but not with others. I'll give it a try and let you know. thanks
That's great.
I'll do that myself now. Thanks
Ouch.
That didn't help. I'm watching slide shows now. Going back to the 5/5 firmware that continues to play all hi bit rate files very nicely. Nothing since then has and this ones the worst, sorry <G>. Quote:
I have one BLU_RAY rip that stutters like crazy. Others seem to be ok. Could that issue be related to this?
_Demo_ |
_Demo_ |
I have not tried it with 0702 yet. I'll let you know...
I got home and updated to 0702 and had the same issue when playing this particular Blu-ray.
One of the m2ts files shows a video data rate of 18858kbps, total bitrate 19114. Audio bitrate is 256 kbps. Edit: This is not much more than another blu-ray which plays fine. I don't consider this a huge issue since I can view it from the server using another player but am providing the information FYI. Last edited by ace007; 07-02-2009 at 04:01 PM. Reason: Added more info |
_Demo_ |
Okay
702 is much better then 701. Not a slide show, but still have occasional stutters unlike 505 which is nearly perfect. My test is an Iron Man blu ray sitting in a blu ray drive on my sage server. So 505 has been great for playback of blu rays in drive and blu ray rips with last many versions of the server betas. No firmware since then has been and I've tried them all. Haven't tried newest firmware with the 19 release candidate, but don't expect that will make any difference?? Thanks
miniplayer/forced_max_push_size=32768 in your Sage.properties file. This is needed to work around the readahead and cache settings of some operating system and drive. _Demo_ |
I'll upgrade to 6.5.19 and then change the suggested setting, but, I always test with a blu-ray rip as well as the disc in drive and both have always failed since 505 and 505 works well with all blu-ray rips and discs in drive.
Please fix the primary/secondary screen bug | timg11 | SageTV Beta Test Software | 4 | 05-04-2009 03:29 PM |
pvr-350 only EOF Bug fix ? | Diem | Hardware Support | 4 | 02-17-2006 11:50 PM |
Bug Fix List?? | m0ng00se30 | SageTV Beta Test Software | 6 | 02-19-2004 04:12 PM |
Fix for Music Bug in V2 | Narflex | SageTV Beta Test Software | 20 | 01-29-2004 08:12 PM |
(Possible) Bug Fix request | TJDmobile | SageTV Recorder Software | 0 | 03-03-2003 11:39 AM |
