If you frequently use the Online Services available in Sage you will notice that your temporary directory tends to get full of files that start with OnlineVideo and .rsslib4j. Sage is supposed to cleanup after itself but under some circumstances it is not able to do so. This STVi allows you to either manually, or periodically at user-defined intervals, delete these temporary files that are no longer needed.
To install:
Usage: Once imported navigate to Setup->Detailed Setup->Customize->Online Video Options. Select "Configure" and you will notice "Automatic Cleanup". Select "Configure" and the options menu will be displayed. Explanation of Options:
Sometimes after running an automatic or manual cleanup you will notice that the number of old items is not 0. This is normal. When Sage creates these temporary files it keeps track of them which causes them to become locked and then deletes them when Sage exits. (Actually when the Java Virtual Machine exits.) So if all goes as planned the temporary items are deleted automatically each time Sage exits. When things do not go as planned this STVi cleans up the mess. If you are using PlayOn and the Hulu plugin you may notice that temporary items also buld up in the Documents and Settings\All Users\Application Data\MediaMall\Media\<IP>\ subdirectory and in your Temporary Internet Files subdirectory. This STVi does NOT cleanup those places since, in general, PlayOn cleans up after itself pretty well. Download Here: http://forums.sagetv.com/forums/down...do=file&id=373
It tells me that I don't have permission to download
Wayne
Asus Commando MB | Intel Core Quad Q9400 CPU | 500 GB WD system drive | (2) 1TB Seagate drives pooled | 2 GB DDR ram | Viper HD4650 video card | Win 7 64 bit | SageTV 9 | (5) Sage HD TV extenders | (1) HDHomeRun Connect for HD OTA | (1) Older HDHomeRun set for HD OTA | (2) HD-PVR'S recording from 2 Dish Network VIP 211K's with Uirt ir control | MX-700 Home theater remote | 60" LED TV | (4) 32" Lcd TV's |
I had the link posted incorrectly, Andy has fixed it so it should work now. Sorry about that.
will this work with SageMC?
I doubt it. SageMC does not actually handle the Online Services, it loads the default STV to take care of that. It would be possible to make it work with SageMC but it probably will not work right now.
The Online Cleanup code is called when the application starts. When SageMC loads the default STV I do not think the application startup code gets called, hence the Online Cleanup code will not get called. Tom
Bummer that it won't work with SageMC. Thanks anyway for your work on this.
STV Import: Malore Style Online Browser | tmiranda | SageTV Customizations | 72 | 09-14-2010 08:52 AM |
STV Import: Malore Style Online Browser | tmiranda | Customization Announcements | 2 | 04-25-2010 05:19 AM |
STV Import: Online Cleanup | tmiranda | Customization Announcements | 0 | 04-18-2010 04:56 PM |
STV Import: SageMC Enhancements (incuding Import Folder Fix in 6.2.x) | twieder | SageMC Custom Interface | 59 | 05-06-2008 01:42 PM |
