Old 07-29-2010, 02:02 PM
PeteCress's Avatar
VAIO Laptop: Goofy Screen
Installed 'Shifter on a brand-new Sony VAIO laptop.
Somewhere along the line Sage issued a dialog to the effect that it had found/fixed a display incompatibility problem.
But here's what I get when trying to view a program:
http://tinyurl.com/2f2hthx
Anybody have some thoughts?
BTW, SlingBox renders a-ok.
Program Source: OTA antenna
Old 07-29-2010, 02:26 PM
GKusnick's Avatar
GKusnick GKusnick is offline
Have you tried turning off 3D acceleration?
-- Greg
Old 07-29-2010, 04:51 PM
PeteCress's Avatar
I can't find anything that looks like 3D accelleration.
Looked in the Intel "Graphics Properties" dialog, but no luck.
Found something called 3D | 3D Preference | Performance that had a little slider control that was sitting in the middle of the range.
I slid it all the way to the left for "Performance", no luck. Slid it all the way to the right ("Quality") and no luck either.
The text menus look fine. It's just the video that's wacked.
Old 07-29-2010, 04:57 PM
GKusnick's Avatar
It's in the Placeshifter settings dialog.
-- Greg
Old 07-29-2010, 05:46 PM
PeteCress's Avatar
Bingo!
But it was the other way around: disabled by default.
I enabled it and the problem went away.
Disabled it and the problem returned.
Slam-Dunk...
Good screen or laptop for outdoor use taylormadearmy Hardware Support 5 06-09-2008 07:57 AM
Sony VAIO VGX-XL1 "Digital Living System" and Sage? kpsmith Hardware Support 7 04-02-2007 08:36 AM
Laptop hardware musemaker Hardware Support 2 05-05-2006 05:08 PM
Sony's Vaio Type X Desktop.... with 7 tuners... PaulG General Discussion 0 07-15-2005 10:10 PM
Sage on Laptop? Dan SageTV Software 1 12-15-2003 09:55 AM
