Old 02-01-2011, 12:49 PM
Hornet's Avatar
Hornet Hornet is offline
Plugin to show tuner used
It was always informative for me to see which tuner recorded the show. With multiple tuners, sometimes it's the only way to tell if a Tuner is not working properly. We used to have that in v6 SageMC but I have not found a plugin for it in Ver7 default SVT. Has anyone done this and I have just not found it ? I know it's on the recording detail page, but it was nice to see the information along with HD, 1, etc.
Windows Vista Home Premium
2.40 gigahertz Intel Core2 Quad Q6600
4 Meg Ram
HDHR, Hauppauge WinTV HVR-1800
1.5 TB USB SATA Drive
Old 02-01-2011, 12:58 PM
QueOnda's Avatar
QueOnda QueOnda is offline
you can use the webadmin (you have to install it first as a plugin v7). Then you can see what tuners are being recorded.
As for if you already have a recording show, you can look at the detailed info and tells you what tuner was used to record. Not sure if this is native in V7, but I'm using several plugins which may have added the info.
Server: HP AMD64 dual core running Win7 64bit (MCE disabled) with 4G memory Tuners: 2 PVR-500(disabled), 3 HDHR and 1 HDPVR Clients: 2 HD200 and 1 HD100 TV: 70" and 52" and 42" Media Storage: ReadyNas 8TB Recording media: 300GB + 200GB+ 250 GB Network: Gigabit backbone'
Thanks to all the developers who work on SageMC, code, utilities and plug-ins to make SageTV better!!!
Old 02-01-2011, 01:04 PM
System Information screen also shows what is currently recording and which tuner is recording it. But the OP wants that info in a more convenient spot. There is a v7 plugin for this but it didn't work for me.
Old 02-01-2011, 04:46 PM
SageMC still works in V7...
[PLUGIN] Always Show SubMenus Fuzzy SageTV v7 Customizations 13 02-27-2011 06:55 PM
dflachbart Tweaks plugin - Show encoder markers mkanet SageTV v7 Customizations 5 01-10-2011 07:59 AM
Is there a sagetv plugin or import allowing to sort and show only current movies thenewguy1979 SageTV Customizations 9 09-14-2008 10:57 PM
custom tuner plugin ophois Hardware Support 3 05-28-2007 12:32 PM
STVi plugin request: Send TV show detailed info to an email recipient mkanet SageTV Customizations 1 01-22-2006 03:59 PM
