Old 03-12-2012, 03:28 PM
bigo93bronco's Avatar
bigo93bronco bigo93bronco is offline
A Few Placeshifter Q's
My new job requires alot of travel and hotel stays, so I'm really getting into the placeshifter side of Sage. I have a reletively slow upload speed on my home ISP, and I'd like to adjust the size of the playback buffer on the placeshifter. Where is the properties file for the placeshifter located? Server or placeshifter side? I haven't had too many issues with video playback so long as I pause the video for a few seconds before I start watching it. The menus are very slow however. Are the menus "processed" on the server side or the placeshifter end? I installed the placeshifter program onto my laptop which allready had a registered and legit installation of sagetv client installed. I did this about a month ago and the placeshifter trial never locked the program out (although it still reminds me that it's a trial). Could the fact that I have both programs installed be causing issues with the menus? I installed the placeshifter program to a different folder then the client.
like this : programfiles/sagetv
sagetv
common
placeshifter
Windows 10 X64 ASUS Z270 TUF2 MOBO
Intel I5 Kaby Lake @3.3 Corsair H65 AIO water cooler
16GB GSkill DRR4 10 SATA hotswap bays in 4U RM case
Redundant power supply, dual UPS's, etc
Samsung EVO 850 SSD X2 OS drives
WD 4TB Purple drive for recordings, various other drives for archives
Tuners are a work in progress
Old 03-13-2012, 10:19 AM
WOW,
Not as much traffic on this site as there used to be Does anyone know what properties file effects the placeshifter client?
Old 03-20-2012, 06:06 PM
routerunner's Avatar
The placeshifter should have the MAC address of the server where SageTV is running on, but because is a kind of client I would expect the .properties file in the clients folder. The SageTV instance you have on the server has a MAC address set as "null".
The whole UI is generated on the server side. However the placeshifter uses a proprietary VBR compression that tries to optimize the throughput by constantly monitoring your internet connection. I use sometimes placeshifter from work through a VPN channel to my home server and considering that my upload speed is about 1.5Mbits the result is pretty decent.
sagetv
common
placeshifter
I don't think so
MCE & Placeshifter in 6.1.4 Mahoney SageTV Beta Test Software 0 03-13-2007 02:44 PM
Placeshifter in 6.1.3 RC gblinckmann SageTV Beta Test Software 0 02-21-2007 09:22 PM
Thank You! (Mac Placeshifter) nicktripp SageTV Placeshifter 5 12-30-2006 11:06 PM
Thanks for Placeshifter!! ChePazzo SageTV Placeshifter 3 06-16-2006 04:27 AM
