Old 12-09-2008, 05:52 PM
benjamintm benjamintm is offline
Adding to Recordings
Is there a way to add video files to the SageTV Recordings? The use case is where I have a video podcast that is downloaded via a podcatcher program. I would then want this podcast to show up in my SageTV Recordings screen.
My assumption is that I would need to provide the metadata for the file (show name, episode name, description, etc.), which I can easily create from the podcast XML. The question would then be how can I get this information to into the SageTV Recordings database?
Looking at the .properties file this doesn't seem right as it appears to import into the videos section of Sage.
Ben
Old 12-10-2008, 07:55 AM
AFAIK anything other than TV recordings will show in the video section. You could create a filter to only show your podcasts and that will make it easier to find.
Old 12-10-2008, 12:14 PM
GKusnick's Avatar
GKusnick GKusnick is offline
The webserver plugin has the ability to import airing metadata into the Sage DB from (properly formatted) XML. That should allow you to do what you want (although I haven't actually used this feature myself).
-- Greg
Old 12-12-2008, 03:26 PM
Thanks. I will have to give that a try.
Ben
Old 12-21-2008, 02:08 AM
mwhittaker1024 mwhittaker1024 is offline
Can you post here if you're able to get it to work? I would like to be able to do this as well.
Mark J Whittaker
SageTV FAQ Narflex SageTV Software 45 04-15-2011 08:34 AM
Tivo HD Recordings in SageTV Media Center chubb SageTV Software 0 09-10-2008 06:09 AM
Placeshifter Crashes on SageTV Recordings Menu Yorick SageTV Placeshifter 1 08-30-2008 08:25 AM
Windows Client - No Recordings ntk2 SageTV Beta Test Software 1 08-01-2008 11:26 AM
Recordings Orphaned, Cannot Recover DON3k SageTV Software 5 03-17-2008 11:47 AM
