Old 07-07-2009, 09:34 PM
MrD MrD is offline
DTV USB/Serial Control
fyi,
to save yourself countless hours of stupid trouble shooting the latest firmware 42EB on the DTV-H2x receivers seems to have busted the USB/serial channel control.
[size=1]-MrD
Linux Server 7.1.9 (1)HD300 (1) HD200 (1) HD100 (2) PC Clients
Intel Xeon L? 32Gb
CetonTV cable card /FIOS
Old 07-08-2009, 07:49 AM
I have an H21 and still ahve no problems....when did the firmware download to your box?
Also, i'm using the EXETuner plugin instead of Sage's built in support. Perhaps that's the difference the plugin uses and exe caleld directv.exe to change channels...
Old 07-08-2009, 04:17 PM
MrD MrD is offline
How are you using EXEtuner and serial control? Sage has built in support for DTV serial control.
It's the serial control on the receiver (i.e. usb port) that is now broken.
[size=1]-MrD
Intel Xeon L? 32Gb
Old 07-08-2009, 06:38 PM
HelenWeathers's Avatar
According to Paterson's web site only the H21-200 is affected and on that model the USB port is disabled.
Here's a quote from the site:
July 8, 2009 - An update for H21-200 receivers from DirecTV disables the USB port. Stay tuned while we work with DirecTV to resolve this issue.
Old 07-08-2009, 08:16 PM
Well, just before Sage ahd the direcTV serial control working proerly on the H21, I had gone the route of trying out the EXEtuner plugin. The registry key points to an exectuable that runs to chagne the channel. I got the executable from a GBPVR forum for changing DirecTV channels via command line. A google search could find it for you.
Since I was successful in that experiment, I have used the motto, "If it ain't broke, don't fix it" many times when temped over to using the built in support.
Old 07-08-2009, 09:56 PM
MrD: Did you try shutting down your system and unplugging your receiver for a few minutes before restarting your whole system and repowering your receiver??
Old 07-09-2009, 11:20 AM
71_Cuda 71_Cuda is offline
I have two DTV receivers (1 H20 and 1 HR20), and I'm using the built in Sage serial control on the H20 and the EXETuner plugin for the HR20. I was using the EXETuner on both initially. My reason... I had an OTA antenna integrated into the boxes and I needed the directv.exe app (used with EXETuner) to be able to send the dashes "-" for the subchannels. The built in SageTV serial control can't send dashes. That's a problem for integrated locals and any other dashed subchannels DTV may use. Mine were working fine for a while. Then I started having problems with the HR20. It would only receive the first digit. Usually rebooting the box would fix it, but after 1-3 days the problem would return. It became unreliable and a nuissance. I switched serial tuning for that box to the built in Sage option and it's worked fine since. Of course I can't tune locals on that one anymore. But that's not a problem since I ended up with 3 OTA tuners trying to solve another problem. I've just made those top priority and set the HR20 to 5th priority. The chances of it needing to tune local now are VERY slim - and I don't currently have other subchannels.
I'm wondering now it my HR20 problem with the EXETuner had anything to do with a firmware update.
Old 07-09-2009, 11:23 AM
Originally Posted by MrD View Post
fyi,
I see you have an H20 as well as an H21 receiver. Can you confirm - did it bust it on the H20, too. Or is it just the H21 as Helen indicates from the Patterson website?
Old 07-09-2009, 12:31 PM
FYI: I have two H20s (H20-100s) and they are both working fine with the most current firmware for them.
Old 07-09-2009, 03:18 PM
MrD MrD is offline
Oh yeah the H20 still works no problem.
[size=1]-MrD
Intel Xeon L? 32Gb
Old 07-09-2009, 03:23 PM
MrD MrD is offline
Yes. I also had a spare patterson device that I swapped out.
I have the system installers test app and I am going to try a null modem cable tonight.
btw, my last H21 died after plugging and un-plugging it (i.e. it never powered up again). So I get a little nervous when I do that step.
[size=1]-MrD
Intel Xeon L? 32Gb
Old 07-10-2009, 07:56 AM
bhyman1 bhyman1 is offline
It wold seem that my H21-200 is no longer changing channels with serial control either.
My H21-100 still works fine though.
Old 07-11-2009, 07:33 AM
MrD MrD is offline
my h21-200 is working again after the reset and turn off usb reset on the patterson device
[size=1]-MrD
Intel Xeon L? 32Gb
Old 07-11-2009, 11:57 AM
Polypro Polypro is offline
Thank you for this post. H21-200's here...and they stopped working as well.
Can you walk me through exactly how you got them working again, including how to update the Paterson Device (If Needed). I could never figure out how to Interact with the Paterson (Do I plug it into a serial port on an old motherboard?) Thanks, P
Old 07-11-2009, 03:43 PM
I just read over on DBSTalk that apparently you can fix this by leaving the USB device plugged in, hitting reset on the receiver, and then waiting a few minutes for the USB communiactions to come back.
So I'l give this a try tomorrow once I'm home.
Old 07-11-2009, 08:05 PM
MrD MrD is offline
my setup:
patterson serial side plugged into pci serial card on pc (also note that I have had success using usb to serial adapters too, i.e. plug usb serial into PC plug patterson into serial adapter)
patterson usb side plugged into receiver usb port
corrective action:
plug patterson usb side into PC usb port
run tv translator patterson software
run test mode (verify test completed ok)
uncheck the "usb reset" check box
plug patterson usb side into receiver
press reset button on the receiver
wait
restart sage (may or may not be necessary)
verify that channels change
[size=1]-MrD
Intel Xeon L? 32Gb
Old 07-12-2009, 03:54 PM
Thanks for the instructions. Before I unhooked the Patersons, I decided to try a power off (unplugged) reset of the 2 STB's. I powered them off with the front panel power buttons and then removed the power cables. I let them sit for about 15 min (not that that matters...1 sec is probably good enough) and then plugged them back in. After letting them sit for another 10 min or so, I added them back in to sage...and they worked! Serial changing was back to normal. Is there a way to NOT get updates on these boxes?...a way to block DTV from pushing stuff down?
P
Old 07-31-2009, 09:24 PM
toricred's Avatar
toricred toricred is offline
I've been fighting with this same problem every 2 days or so. I have 4 serial controlled H21's. After pulling the plug and re-inserting it works for a couple of days. I have at least one that is using the patersontech and at least one using usb-serial->null modem->serial-usb. Any other ideas to fix this?
Old 08-01-2009, 10:05 AM
Have your tried just a straight up red-button reset after everything is on?
Old 08-01-2009, 11:52 AM
toricred's Avatar
I have just started doing that after reading this thread, but I'm still after a way to not even need that.
DTV Serial Control broke?? 4T2 Hardware Support 2 04-16-2008 09:01 AM
DirectTV serial control on dtv only? ryan711 Hardware Support 1 01-13-2006 11:43 PM
DTV Serial Control in sage 1.48 kevthor SageTV Software 20 01-16-2004 04:18 PM
serial control of dtv ashenshugar SageTV Software 1 08-06-2003 06:49 AM
Thanks for the DTV Serial control... gpurcey SageTV Beta Test Software 1 08-01-2003 10:43 AM
