Universal Remote to Control MediaMVP unit?
Folks - anyone had any luck getting a Universal Remote to control even the simplest functions (Stop, Play, REW, FF, and such) of the MediaMVP units? I've recently purchased a "ONe For All" Brand Universal Remote (Model # URC-6131), and the things has TONS of codes to choose from. Even though no Hauppauge specific codes, I though maybe one of the VCR or DVR/PVR Related codes it has for other manufactures might work - even if just a little. I guess it would have been smarter for me to buy a "learning" remote - but I didn't think of the MVP unit at the time..... Thanks!!
Aloha, Mike
"Everything doesn't exist. I'm thirsty." ...later... "No, it's real!!! I'm full." - Nikolaus (4yrs old) |
Yes, the JP1 links in that post or the Philips codes would be things to look into. Also try contacting OFA... I may be wrong, but I thought they had some Hauppauge device codes they can give over the phone or something.
I bought 2 URC remotes....
URC 9910 and URC 8820 both are learning remotes and JP1 programmable. The 9910 was about $35 and the 8820 was about $20 on Amazon.com The way to use these for Hauppage/MVP is through the learning function. Just use the current 45 button hauppauge remote to "teach" the new remote. I didn't even try to find an overall "code" The 8820 is probably all you need. But, the 9910 emits both an IR and RF signal at the same time, thus opening up other posibilities such as changing channels and input sources from another room...Comes in handy when you want to use a cable box in another room that inputs through S-video to a PVR 150 card. Hope it helps, Gary |
In case you want to splash around while watching sage...
Then this one works just fine too. Dolphin Universal Remote It controls the MVP from the tub while watching this: Seura mirror TV I will probably post this whole setup in another thread once I have some spare time. |
