SageMC Custom Interface This forum is for discussing the user-created SageMC custom interface for SageTV. |
IMDB description not downloaded and Where do TV series images come from?
I'm still in the process of getting Sage set up and am now in fine-tune mode. I do have two outstanding questions:
1) When I select download IMDB information, I am able to pull down the image of the movie and sometimes trivia and quotes, but I never get the main information for the movie. Does anyone have a similar experience or know what might be causing this? 2) I've noticed that some programs I watch have TV series images that show up in the OSD (SAGEMC) and on the program guide. What triggers Sage to download and use these images? I like it and would like to see more of these available. Thanks |
Anyone?
If your movies are in ripped CD format Sage will look for a file called folder.jpg in the VIDEO_TS directory. If none is found it will use the generic DVD icon, which can be modified if you like. If the movie is in a single file Sage will look for a file called xxx.jpg where xxx is the name of the video file. If it does not find the .jpg it will generate a thumbnail. I can't help with the first question since I rarely use IMDB.
I'm using Sage 6.3.10 with latest SageMC
If this doesn't work right, Then: "I'm going to blow up the Earth!" |
To further expand on tmiranda's note... see this sticky in the customization forum.
Seems misery loves company. Anyone know how to get this to work?
Grab the latest jar file from nielm's IMDB import, drop it into your JARs folder, and restart SageTV.
Aloha, Mike
"Everything doesn't exist. I'm thirsty." ...later... "No, it's real!!! I'm full." - Nikolaus (4yrs old) |
Do I install the full stvi or just take out the jar files and put them in manually?
Yup. Just grab the jar files.
Problem solved. Thank you.
