Harmony Setup
What is the best way to set up the Harmony remote for the HD-100? SageTV is not in the Setup options, or I cant find it. Is it under a different brand name?
I would use the computer program and do a manual setup where you point the two remotes at one another and when the computer tells you, press the button on the Sage Remote.
Which Harmony did you get?
Media Server: Win 7 Home (32 bit), GIGABYTE GA-EP43-UD3L LGA 775 Intel P43 ATX Intel Motherboard, Intel Core 2 Quad Q9505 Yorkfield 2.83GHz, 4 GB Ram, Geforce 9600 GT PCI-E, 1x HD PVR, HD homerun (2x for OTA, 1x for FIOS QAM), 1 x HD Homerun Prime with cablecard from FIOS. Client: Windows 10 Pro Media Extenders: HD-200 x 3, HD-200 x 2 |
I would advise against that. The SageTV remote is a RC5 protocol and that would likely not work so well and have issues with double button presses.
Harmony has a profile for SageTV under Media Centers. Just search for the model name STX-HD100 B
Running SageTV on unRAID via Docker Tuning handled by HDHR3-6CC-3X2 using OpenDCT |
There's a sticky for this, also pointed to from the extender FAQs: Information Resources for Remotes, Receivers, and IR Blasters
Thanks all for you help |
I just got the same remote, setup SageTV profile... and get no response. Currently using Hauppage remote with included MCE-150 IR cable... what am I doing wrong?
Tags |
harmony, logitech |
MyBlaster: Need driver setup software | TheBigGuy | Hardware Support | 6 | 06-18-2017 03:44 AM |
Problems with Channel Setup / Hauppauge NOVA-HD-S2 | stani | SageTV Software | 0 | 10-11-2007 03:52 AM |
Sage and Fusion Lite setup? | gateslinger | Hardware Support | 5 | 07-10-2006 02:23 PM |
how to setup listener/hook for close/alt+F4 | koelec | SageTV Studio | 5 | 06-23-2006 01:14 AM |
Multiple Tuner Setup..Please Help | garyellis | Hardware Support | 4 | 06-03-2006 09:21 AM |
