Unable to change 4 digit channels with MCE remote?
I'm wondering if anyone else has seen this problem. Using the MCE remote I cannot change to a 4 digit channel. I'm using LM Remote Keymap to change the channels on my Motorola 6100. Testing a 4 digit channel from within the LM Remote program manually works fine, but the remote seems to transmit 3 digits, then an 'ok' or 'enter', then the fourth digit. So if I enter 1729, it seems to send 172, ok, then 9. So of course I end up with channel 9. Changing the delay between digits doesn't do anyhting either.
I tried changing the 'digits per channel' in Sage's video setup/remote control options, but it doesn't retain any changes that I make, so it goes back to the default of 0. I'm wondering if it's perhaps a limitation of the MCE remote? |
I have the same problem but I cant tune nything more then 2 channels. I send 180 and it enters 18.
Im using EXETuner, with HIP though. Havent got an answer on my thread yet |
For not overloading the trace viewer, use your mouse to tune to a four digits channel withing the guide. You'll then see in the trace viewer what channel number SageTV has requested. |
Using MCE's IR blaster with Sage | Steerpike | Hardware Support | 121 | 03-22-2008 10:01 AM |
MCE Remote not work fully with Placeshifter | devinteske | SageTV Placeshifter | 5 | 02-08-2007 11:45 PM |
MCE Remote Setup | mirage01 | Hardware Support | 1 | 02-11-2006 12:18 PM |
Unable to enter double digit channels | sabre | SageTV Software | 6 | 11-15-2005 01:20 PM |
How to change channels with Hauppauge remote | Terrapin | Hardware Support | 10 | 10-05-2005 02:25 PM |
