comskip and Oprah
The WAF has dropped like the Dow Jones index, as she commented that comskip isn't detecting commercials correctly. I'm wondering if there are any tried and true tricks to optimize this series specifically? i'm running comskip 79_144. Ini follows:
detect_method=127 ;1=black frame, 2=logo, 4=scene change, 8=fuzzy logic, 16=closed captions, 32=aspect ration, 64=silence, 128=cutscenes, 255=all validate_silence=1 ; Default, set to 0 to force using this clues if selected above. validate_uniform=1 ; Default, set to 0 to force using this clues (like pure white frames) if blackframe is selected above. validate_scenechange=1 ; Default, set to 0 to force using this clues if selected above. verbose=10 ;show a lot of extra info, level 5 is also OK, set to 0 to disable max_brightness=60 ;frame not black if any pixels checked are greater than this (scale 0 to 255) test_brightness=40 ;frame not pure black if any pixels checked are greater than this, will check average brightness (scale 0 to 255) max_avg_brightness=25 ;maximum average brightness for a dim frame to be considered black (scale 0 to 255) 0 means autosetting max_commercialbreak=600 ;maximum length in seconds to consider a segment a commercial break min_commercialbreak=25 ;minimum length in seconds to consider a segment a commercial break max_commercial_size=125 ;maximum time in seconds for a single commercial or multiple commercials if no breaks in between min_commercial_size=4 ;mimimum time in seconds for a single commercial min_show_segment_length=125 ; any segment longer than this will be scored towards show. non_uniformity=500 ; Set to 0 to disable cutpoints based on uniform frames max_volume=500 ; any frame with sound volume larger than this will not be regarded as black frame min_silence=12 ; Any deep silence longer than this amount of frames is a possible cutpoint ticker_tape=0 ; Amount of pixels from bottom to ignore in all processing logo_at_bottom=0 ; Set to 1 to search only for logo at the lower half of the video, do not combine with subtitle setting punish=0 ; Compare to average for sum of 1=brightness, 2=uniform 4=volume, 8=silence, 16=schange, set to 0 to disable punish_threshold=1.3 ; Multiply when amount is above average * punish_threshold punish_modifier=2 ; When above average * threshold multiply score by this value intelligent_brightness=0 ; Set to 1 to use a USA specific algorithm to tune some of the settings, not adviced outside the USA logo_percentile=0.92 ; if more then this amount of logo is found then logo detection will be disabled logo_threshold=0.75 punish_no_logo=1 ; Default, set to 0 to avoid show segments without logo to be scored towards commercial aggressive_logo_rejection=0 connect_blocks_with_logo=1 ; set to 1 if you want successive blocks with logo on the transition to be regarded as connected, set to 0 to disable logo_filter=0 ; set the size of the filter to apply to bad logo detection, 4 seems to be a good value. cut_on_ar_change=1 ; set to 1 if you want to cut also on aspect ratio changes when logo is present, set to 2 to force cuts on aspect ratio changes. set to 0 to disable delete_show_after_last_commercial=0 ; set to 1 if you want to delete the last block if its a show and after a commercial delete_show_before_or_after_current=0 ; set to 1 if you want to delete the previous and the next show in the recording, this can lead to the deletion of trailers of next show delete_block_after_commercial=0 ;set to max size of block in seconds to be discarded, set to 0 to disable remove_before=0 ; amount of seconds of show to be removed before ALL commercials remove_after=0 ; amount of seconds of show to be removed after ALL commercials shrink_logo=5 ; Reduce the duration of the logo with this amount of seconds after_logo=0 ; set to number of seconds after logo disappears comskip should start to search for silence to insert an additional cutpoint padding=0 ms_audio_delay=5 volume_slip=20 skip_b_frames=0 ; Set to 1 to force Comskip to skip frames for higher processing speed. max_repair_size=200 ; Will repair maximum 200 missing MPEG frames in the timeline, set to 0 to disable repairing for players that don't use PTS. disable_heuristics=4 bit pattern for disabling heuristics, adding 1 disables heristics 1, adding 2 disables heristics 2, adding 4 disables heristics 3, 255 disables all heuristics delete_logo_file=0 ; set to 1 if you want comskip to tidy up after finishing output_framearray=0 ; create a big excel file for detailed analysis, set to 0 to disable output_data=0 ; create a dump of the user data channel, used for CC and XDS (such as V-Chip info). Can be use together with output_framearray to remote debug CC decoding output_videoredo=0 output_womble=0 output_mls=0 ; set to 1 if you want MPeg Video Wizard bookmark file output output_cuttermaran=0 output_mpeg2schnitt=0 output_mpgtx=0 output_dvrcut=0 output_zoomplayer_chapter=0 output_zoomplayer_cutlist=0 output_edl=1 output_edlx=0 output_vcf=0 output_bsplayer=0 output_btv=0 ; set to 1 if you want Beyond TV chapter cutlist output output_projectx=0 ; set to 1 if you want ProjectX cutlist output (Xcl) output_avisynth=0 output_vdr=0 ; set to 1 if you want XBMC to skipping commercials output_demux=0 ; set to 1 if you want comskip to demux the mpeg file while scanning sage_framenumber_bug=0 sage_minute_bug=0 live_tv=0 ; set to 1 if you use parallelprocessing and need the output while recording live_tv_retries=4 ; change to 16 when using live_tv in BTV, used for mpeg PS and TS dvrms_live_tv_retries=300 ; only used for dvr_ms standoff=0 ; change to 8000000 when using live_tv in BTV cuttermaran_options="cut=\"true\" unattended=\"true\" muxResult=\"false\" snapToCutPoints=\"true\" closeApp=\"true\"" mpeg2schnitt_options="mpeg2schnitt.exe /S /E /R25 /Z %2 %1" avisynth_options="LoadPlugin(\"MPEG2Dec3.dll\") \nMPEG2Source(\"%s\")\n" dvrcut_options="dvrcut \"%s.dvr-ms\" \"%s_clean.dvr-ms\" " windowtitle="Comskip - %s" |
That is a strange setting.
Why have detect_method at 127?
Support Comskip, visit the forum and donate at http://www.comskip.org/ |
I don't have any answers...but my WAF is low for Oprah also (most other shows are great).
Based on my analysis, Oprah has quite a few "cut scenes" where they profile a person or something, that has similar characteristics to and ad. Have not found any way to avoid via comskip, so I have turned off "auto-skip" in SageMC under the Comskip settings so now at least she can watch the "cut-scene" without it auto skipping past it. Downside is that you have to manually hit the skip button on the remote to skip "real" commercials. |
I have no clue. I'm not sure i ever touched anything in that file, other than the various output options.
But its not the default ini that comes with comskip
judging by what is on the comskip.org site, i assume your recommended default is detect_method=111, so that's what i changed it to last night. Unfortunately, it seems today's Oprah was a repeat, so Sage did not record it since it was previously watched. Thus i have no WAF feedback on the setting change.
However, i will say this change did seem to fix one of my CNBC shows, Fast Money, that invariably didn't detect a commercial correctly (the inverse of the Oprah problem). I can only conclude, that in my initial naiveté, i changed the setting without documenting it...(me being an IT manager, i know that never happens.. ![]() If there is an increase in WAF from watching Oprah via Sage skipping commercials due to this change, i will dutifully report such news back here. |
Please follow the "how to ask for help" topic in the comskip support forum and I will be glad to help increasing the WAF
Server: Sage 9.0.13.536, Windows10-64bit, AMD Phenom II X4 905e 2.5GHz , 16GB Ram, 2.6TB recording Tuners: OpenDCT 0.5.2 Ceton InfiniTV4 NAS: 16TB, unRaid Plus, Asus H87I-Plus mini-ITX, Intel Core i3-4130, 16GB Ram, Fractal Node 304 case 10 Clients: HD-300, HD-200, SageWin10, Plex, AndroidMiniClient |
