Old 06-12-2009, 02:44 PM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
Problem with channel re-scan after June 12th transition
After doing a re-scan, I'm getting "no signal" on all my over-the-air stations. I noticed in the frq file that the frq parameter is set to 1, rather than the frequency in the prior file. I know I can copy over the frq information for the channels that have not changed, but it's an issue for the channels that have been re-assigned. This is affecting both my HD Homerun tuner and Pinnacle 801SE. I'm running the 6.5.17 beta. Please see below:
***After scan today****
CH:1 major:19 minor:1 prog:1 phy:18 frq:1 #:KUVS-DT
CH:2 major:31 minor:1 prog:1 phy:21 frq:1 #:KMAX-DT
CH:3 major:13 minor:1 prog:1 phy:25 frq:1 #:KOVR-DT
CH:4 major:3 minor:1 prog:1 phy:35 frq:1 #:KCRA-DT
CH:5 major:3 minor:2 prog:2 phy:35 frq:1 #:WX-Plus
CH:6 major:40 minor:1 prog:3 phy:40 frq:1 #:KTXL-TV
CH:7 major:40 minor:2 prog:4 phy:40 frq:1 #:LATV
CH:8 major:58 minor:1 prog:1 phy:46 frq:1 #:KQCA-DT
CH:9 major:58 minor:2 prog:2 phy:46 frq:1 #:This-TV
CH:10 major:29 minor:1 prog:3 phy:48 frq:1 #:ION
CH:11 major:29 minor:2 prog:4 phy:48 frq:1 #:qubo
CH:12 major:29 minor:3 prog:5 phy:48 frq:1 #:IONLife
CH:13 major:29 minor:4 prog:6 phy:48 frq:1 #:Worship
CH:14 major:6 minor:1 prog:3 phy:53 frq:1 #:KVIEHD
CH:15 major:6 minor:2 prog:4 phy:53 frq:1 #:KVIE2
CH:16 major:6 minor:3 prog:5 phy:53 frq:1 #:KVIEVme
CH:17 major:0 minor:1 prog:1 phy:61 frq:1 #TV61.1
CH:18 major:64 minor:1 prog:1 phy:62 frq:1 #:KTFK-DT
***Pre-scan***
CH:1 major:10 minor:1 prog:3 phy:61 frq:753250000 #:KXTVDT
CH:2 major:10 minor:2 prog:4 phy:61 frq:753250000 #:KXTVDT2
CH:3 major:40 minor:1 prog:3 phy:55 frq:717250000 #:KTXLDT
CH:4 major:6 minor:1 prog:3 phy:53 frq:705250000 #:KVIEDT
CH:5 major:6 minor:2 prog:4 phy:53 frq:705250000 #:KVIEDT2
CH:6 major:29 minor:1 prog:3 phy:48 frq:675250000 #:KSPXDT
CH:7 major:29 minor:2 prog:4 phy:48 frq:675250000 #:KSPXDT2
CH:8 major:29 minor:3 prog:5 phy:48 frq:675250000 #:KSPXDT3
CH:9 major:58 minor:1 prog:1 phy:46 frq:663250000 #:KQCADT
CH:10 major:58 minor:2 prog:2 phy:46 frq:663250000 #:KQCADT2
CH:11 major:3 minor:1 prog:1 phy:35 frq:597250000 #:KCRADT
CH:12 major:3 minor:2 prog:2 phy:35 frq:597250000 #:KCRADT2
CH:13 major:13 minor:1 prog:1 phy:25 frq:537250000 #:KOVRDT
CH:14 major:31 minor:1 prog:1 phy:21 frq:513250000 #:KMAXDT
Old 06-12-2009, 03:39 PM
I don't think that frq file info for OTA ATSC channels should matter... are you saying that some channels didn't work after the scan, then you copied over lines from the older frq file & those channels now worked?
When configuring the tuners, did you select antenna rather than cable?
Old 06-12-2009, 03:57 PM
jarredduq's Avatar
All I did is re-scan the channels. Through trouble-shooting, etc, I have removed the device, deleted the frq files, and re-scanned.
Yes, if I copy over the old lines with the frq information, they start working again. Yes, I have antenna selected.
I also submitted a support request...
Old 06-13-2009, 12:34 PM
donkey donkey is offline
HDHR's frq issue
There is a blind spot of managing ATSC frequency SageTV working with a HDHR
you either change frq:1 to frq:2000 in the .frq file to have a HDHR take care ATSC frequency or download an update to rescan channel so that you can get correct channel frequencies in the .frq file.
http://download.sage.tv/users/qian/DShowCapture.dll
Qian
Qian
Old 06-15-2009, 12:56 PM
turak's Avatar
turak turak is offline
Thank you! I've been beating my head against a wall for weeks trying to get my HDHR to tune OTA HD channels in Windows 7 RC 64bit. This update seems to have fixed the issue that I was having.
Old 06-15-2009, 01:48 PM
rmac321 rmac321 is offline
Probably a stupid question, but if everything is working at the moment, should we change this file? IOW, is this a problem waiting to happen or will it have already happened if it was going to affect our systems?
SageTV v9.1.10.479 on Ubuntu
(testing v9.1.10.479 on Debian and Win10)
Old 06-15-2009, 02:40 PM
if your HDHR's driver is 20090415 or later, which doesn't create an OTA a scn file for SageTV, I suggest you update in case you rescan OTA channel in SageTV.
Qian
Qian
HD200: Channel Scan Slack SageTV Media Extender 3 06-12-2009 09:27 AM
Channel Scan Files OttoNP SageTV Software 3 12-10-2008 08:25 PM
SageTV no scan channel Yele Hardware Support 1 10-11-2007 01:38 PM
How to manually scan channel dma4620 SageTV Beta Test Software 0 11-12-2006 08:24 AM
Channel Scan - Not scanning Opopanax SageTV Software 2 01-07-2005 12:29 AM
