Old 08-26-2009, 03:36 PM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
HD200 DTS Work-Around
I figured out a potential work-around for DTS. I took one of my HD200's and put it on a separate network from my Sage Server by putting another router in front of it.
Doing this forces the HD200 into place-shifter mode, as it can't see the Sage server directly. While in place-shifter mode, and playing a MKV file with a DTS track, the Sage server trans-codes the audio without needing a DTS decoder on the client side.
The downside to this is that I loose the ability to play DVD's or Blu-ray discs because of being in place-shifter mode.
It would be cool to have this trans-code ability without having to use place-shifter mode.
Old 08-26-2009, 03:38 PM
It transcodes the video too.
Old 08-26-2009, 03:41 PM
jarredduq's Avatar
True, that's why I'm hoping that there would be a way to just trans-code the audio from the server side.
Old 08-27-2009, 04:48 AM
I think eventually, (hope actually) that sage implements on-demand transcoding. This would allow it to transcode JUST the parts it needs (depending on the capabilities of the playback device), and just copy the parts that are already in a supported format. ffmpeg already supports copying streams from input to output, it's just a matter of sage offering some sort of capability handshaking, and passing the proper transcoding flags to ffmpeg.
Old 08-27-2009, 04:57 AM
Lucas Lucas is offline
Transcoding just the audio is difficult/impossible because then the synchronisation with the video could not be maintained.
There is a property which allows the transcoding of DTS and video already.
Have a look here
http://forums.sagetv.com/forums/show...TS+transcoding
3 x HD300s
Old 08-28-2009, 01:51 AM
No, there is no syncronization issues when using ffmpeg's transcoding functions. Video is still passed through the transcoding step, it is just left unchanged (copied), so sync is still maintained.
Old 08-28-2009, 03:18 AM
So it could be a matter of the appropriate parameters being passed on to ffmpeg.
3 x HD300s
Old 08-28-2009, 05:04 AM
yes, that's exactly what it is.. well, that and determining the capabilities of the playback device, so as to know WHAT parameters are to be passed.
Old 08-28-2009, 06:29 AM
dbone1026's Avatar
dbone1026 dbone1026 is offline
Have a look here
In the link the video quality was noted as pretty bad, does that still apply?
I just rely on adding a separate AC3 track in my Blu Ray mkvs/ts files so I can get audio on my HD200 connected directly to my TV.
Cheers
Damian
Blog - http://www.adigitalhomeblog.com
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Old 08-29-2009, 05:59 AM
Currently, yes, adding the AC3 track is probably the best option for ripped media... the limitation comes with playing back blu-ray's directly from the disc.
Old 08-30-2009, 09:54 AM
At the time, my server was pretty low powered so it couldn't do any better.
I think I could get much better quality with my current hardware but haven't tried.....
3 x HD300s
Should USB Flash Drive work with HD200? carlgar SageTV HD Theater - Media Player 9 08-24-2009 09:17 PM
Contemplating adding another HD200; will this monitor work? Hunter69 SageTV Media Extender 2 08-17-2009 10:15 AM
HD200. Will it ever decode DTS? autoboy SageTV Media Extender 20 07-13-2009 02:48 PM
HD200 not playing Dolby DTS sound ... JParedis SageTV HD Theater - Media Player 15 03-07-2009 12:38 AM
WHS HD200 plan will this work Hunter69 SageTV Media Extender 2 02-02-2009 04:05 PM
