Old 08-09-2010, 07:48 PM
jarredduq's Avatar
jarredduq jarredduq is offline
Location: Stockton, CA - Most miserable city in the USA, SageTV makes it bearable
HDHR setup in SageTV 7 on Windows 7
I'm having a bad time trying to get my HDHR to work with QAM. I'm moving, and will not be able to use an antenna. Beforehand, I'm testing my HDHR with Comcast, and I'm performing the channel scan with the HDHR software (Version 20100609beta1).
I can see the FRQ and SCN files in the SageTV program folder. I've also renamed the channels according to the Zap2it guide. I can preview the channels in the HDHR software just fine.
When I set it up in Sage v7.0.14, it finds the channels very quickly, and looks good, but when I try to preview any of the channels, they are all at 0% signal strength.
Some other notes:
*I'm running Windows 7 32-Bit
*Sage v7.0.14
*I have an antenna connected to tuner 0, and Comcast to tuner 1.
*I'll open a ticket with Sage as well
I've attached the FRQ and SCN files, if that helps.
* split & moved to the beta forum *
Server: HP w/Intel i7-4770S CPU @ 3.10GHz , 500GB SSD, 16GB DDR3, Win 10 64-bit, 4TB of SSD for recording
SageTV: 9.2 - 64-Bit
Capture Devices: 2xHD Homerun Prime and HD-PVR (Comcast Premium/Music Channels)
Client 1, 2, 3, and 4: HD200.
NAS: Synology DS220+ 8TB (Movie Storage)
Sage Add-ons: Jetty, Neilms Webserver (Jetty), Mobile Web, Play-On Plug-in, Comskip Plug-in
Old 08-10-2010, 09:16 AM
valnar valnar is offline
Are you running the latest beta firmware/software for your HDHR?
Client 2: HD300 on Vizio 40"
Old 08-10-2010, 09:26 PM
jarredduq's Avatar
Yes.
Old 08-11-2010, 07:47 AM
jarredduq's Avatar
I figured out the problem! In the FRQ file I discovered the the Modulation is set incorrectly as 0, and it should be set at 11. Once I did that it works great. Looks like the Silicondust software is not generating the SCN files correctly, as it is set incorrectly there as well, so Sage is just importing the information it receives. The ol' Garbage in Garbage out issue.
Old 08-12-2010, 09:32 PM
ranger ranger is offline
Blank screen with new HDHR
I just bought a 2nd HDHR and cannot get it to work in Sage. I went through the setup instructions in the SiliconDust site and the instructions here at the Sage site. Running Windows 7, Sage 7.0.15, and latest beta HDHR driver. The SCN file generate, the FRQ files generate, but all I get is a blank screen when I try to tune a channel in SageTV. MY first HDHR is working fine so I tried copying the SCN file contents from the original tuner to the new tuner SCN files and re-scanning to generate new FRQ files. Still no change. Not sure what to try next so I am open to ideas.
BTW, I did try changing the modulation to 11, but that had no impact either. Also should note that QuickTV tunes all channels properly.
EDIT - FOUND the problem. had something to do with me missing an obvious issue...
SageTV MC Windows 7 x64 Setup Wizard Hang rabothole SageTV Software 1 07-14-2010 11:00 AM
Tuner setup in Windows 7 and SageTV QuasiInsomniac Hardware Support 4 03-29-2010 11:27 PM
Clarification on HDHR setup pknowles Hardware Support 3 07-28-2009 03:33 AM
Freeview DVB-T setup help (NZ DVB-T HDHR + SageTV 6.5.13 on Linux) akawoz SageTV Beta Test Software 9 04-20-2009 01:09 PM
HDHR setup royhuang SageTV Beta Test Software 5 08-16-2008 12:41 PM
